PM sent.Meisterbravo wrote: Wed Oct 15, 2025 4:33 pm Stumbled unto this thread.
I have the same device as op.
Any chance anyone can help me flash mine ?Code: Select all
Drive Information OS device name: G: Current profile: BD-ROM Manufacturer: ASUS Product: SBW-06D5H-U Revision: E101 Serial number: SJDL148969WL Firmware date: 2018-08-22 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E101/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
After reading all the posts here, I'm pretty sure that I can also read UHD/4K discs with this drive (currently not possible).
Can anyone give me a tip/hint on what exactly I need to do/which tool I need to use for flashing?
It's exactly the same drive as mentioned above, the firmware is from 2018, so well before December 2022.
The operating system is Windows.
Thank you for your help, which I greatly appreciate.
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer:
Firmware-Datum: 2018-08-22
Produzent: ASUS
Revision: E101
Serienummer:
PM sent.xmds2cv wrote: Sat Nov 29, 2025 9:56 pm After reading all the posts here, I'm pretty sure that I can also read UHD/4K discs with this drive (currently not possible).
Produzent: ASUS
Revision: E101
Serienummer:
Thank you for your fast support, flashing worked like a charm!
I have a similar one. Can someone PM me a hint how to make it UHD friendly? I am on MacOS. I can work with the command line stuff but unsure about what firmware to update it with / how. Thank you for your help, I appreciate it.
Manufacturer: ASUS
Revision: E101
Serial number: ...
Manufacturer: ASUS
Revision: E101
Serial number: ...
sure just email me that makemkv drive info section see below for emaillpompa wrote: Sat Jan 03, 2026 3:52 pm I have a similar one. Can someone PM me a hint how to make it UHD friendly? I am on MacOS. I can work with the command line stuff but unsure about what firmware to update it with / how. Thank you for your help, I appreciate it.
Manufacturer: ASUS
Revision: E101
Serial number: ...
i have Drive Information
OS device name: H:
Manufacturer: ASUS
Revision: E102
Serial number:
Firmware date: 2023-04-20
Firmware version: E102/ID26
told i seen a similar theme.
if i could get some tips how to flash this, that'd be appreciated. thank you!
OS device name: H:
Manufacturer: ASUS
Revision: E102
Serial number:
This can’t be flashed as the firmware is post 11/2022.linkjr wrote: Fri Jan 23, 2026 2:24 am i have Drive Information
OS device name: H:
Manufacturer: ASUS
Revision: E102
Serial number:
told i seen a similar theme.if i could get some tips how to flash this, that'd be appreciated. thank you!
Hi all! Is my drive flash-able ? If yes, how ?
OS device name: H:
Manufacturer: ASUS
Revision: E101
Serial number: ADDL209894WL
Thank you!
Viorel
OS device name: H:
Manufacturer: ASUS
Revision: E101
Thank you!
Viorel
Yes just email me that drive info section see below for emailviorelu wrote: Fri Jan 23, 2026 11:09 am Hi all! Is my drive flash-able ? If yes, how ?
OS device name: H:
Manufacturer: ASUS
Revision: E101
Thank you!
Viorel
Email sent, thank you!
Regards,
Viorel
Regards,
Viorel
Good evening,
could I get a bit of help with flashing my new SBW-06D5H-U, please?
I it's based on MT1959 (SDF tool confirms MT1959 platform and unencrypted firmware, both have green checkmark), same as my older 5.25in drive that I successfully flashed, but I have no experience with flashing slim drives and also this drive is not mentioned anywhere on the LibreDrive flashing list.
I'll be glad for any help,
Thank you
Thank you
OS device name: F:
Manufacturer: ASUS
Revision: A102
Serial number: MO2O85I4233
Firmware date: 2124-08-05 14:55
Bus encryption flags: 1F
Highest AACS version: 82
You mean encrypted firmware. Green tick means encrypted.EthanBB wrote: Fri Jan 23, 2026 7:48 pm Good evening,
Thank you
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: ASUS Product: SBW-06D5H-U Revision: A102 Serial number: MO2O85I4233 Firmware date: 2124-08-05 14:55 Bus encryption flags: 1F Highest AACS version: 82 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 No disc inserted
You can flash it to BU40N 1.03-MK.
Sad, I appreciate the reply and time.MartyMcNuts wrote: Fri Jan 23, 2026 4:00 amThis can’t be flashed as the firmware is post 11/2022.linkjr wrote: Fri Jan 23, 2026 2:24 am i have Drive Information
OS device name: H:
Manufacturer: ASUS
Revision: E102
Serial number:
