I am new to the whole backing up my media thing, and I went down the Blu-ray rabbit hole and fell in love with 4k discs, sometimes I wonder if I am going to ruin my collection, so I want to back them up. I thought I bought the correct drive, but it doesn't play 4k discs. Any help is welcome.
thank you
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
can someone help me is this drive flashable for 4k
iphoenix2099
Re: can someone help me is this drive flashable for 4k
Yep, this is a LG drive. It is not 4K UHD capable as is but you can flash it to WH16NS60 1.02-MK and you are good to go.iphoenix2099 wrote: Sat Jan 03, 2026 11:38 pm I am new to the whole backing up my media thing, and I went down the Blu-ray rabbit hole and fell in love with 4k discs, sometimes I wonder if I am going to ruin my collection, so I want to back them up. I thought I bought the correct drive, but it doesn't play 4k discs. Any help is welcome.
thank you
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
iphoenix2099
i flashed it and then received this error
Blu-ray error:
AACS Host certificate revoked.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///F:\'. Check the log for details.
Blu-ray error:
Did you enable makemkv integration for VLC?iphoenix2099 wrote: Sun Jan 04, 2026 6:22 pm i flashed it and then received this error
Blu-ray error:
