Issue with flashing a BU40N
tpglitch
#1 Post by tpglitch » Sat Jan 03, 2026 7:03 pm
Hello guys,
I was trying to flash LibreDrive firmware onto my BU40N drive which currently runs 1.02. I was attempting to flash it to LibreDrive-patched 1.04.
The commands I tried running are:
makemkvcon f -d 'dev_21:0' -f ./sdf.bin rawflash enc -i ./bu40nfirm.bin
makemkvcon f -d '/dev/sr0' -f ./sdf.bin rawflash enc -i ./bu40nfirm.bin
makemkvcon f -d '/dev/sg0' -f ./sdf.bin rawflash enc -i ./bu40nfirm.bin
- Says it could not find /dev/sg0 although the kernel recognizes it.
I double checked it's not in use. `sr_mod` is builtin to the kernel on my distro.
tpglitch
Re: Issue with flashing a BU40N
#2 Post by tpglitch » Sun Jan 04, 2026 12:35 am
Also I am running the OS via a SSD over USB and the drive is directly plugged in via SATA on the PC
#3 Post by MartyMcNuts » Sun Jan 04, 2026 12:37 am
tpglitch wrote: Sat Jan 03, 2026 7:03 pm Hello guys,
If it is an Archgon, they changed the PCB in their enclosure which stops flashing. The drive should be taken out of the enclosure to flash and use.
tpglitch
#4 Post by tpglitch » Sun Jan 04, 2026 6:46 pm
Thanks for your reply! I am aware of that change and yes it is the Archgon BU40N. I did indeed take it out of its enclosure and directly use Slimline sata.
#5 Post by MartyMcNuts » Thu Jan 08, 2026 7:20 am
tpglitch wrote: Sun Jan 04, 2026 6:46 pm Thanks for your reply! I am aware of that change and yes it is the Archgon BU40N. I did indeed take it out of its enclosure and directly use Slimline sata.
Some adapters still don't allow flashing commands to pass through. Check the Ultimate Guide 2026 (and possibly some other threads (use the search function)) as it may have some recommendations for products known to work.
When I first got some bare BU40N drives a few years ago, I used an AC powered SATA to USB adapter along with a SATA to slim SATA adapter.
