deadchip12
#11251 Post by deadchip12 » Sat Jan 03, 2026 1:48 am
@RESET9999
Under the Whitelist setting, I see you select all the 4k option. What does that mean? Will it affect 1080p contents?
Also, what should I set for the Audio Output Device if I have a receiver?
#11252 Post by RESET_9999 » Sat Jan 03, 2026 3:03 am
no
https://justpaste.it/divn9
deadchip12
#11253 Post by deadchip12 » Sat Jan 03, 2026 5:04 am
RESET_9999 wrote: Sat Jan 03, 2026 3:03 am
no
What exactly does that whitelist setting do? I did not select any of the options in there and didn't notice anything unusual.
As for the second question, the link you posted does not mention what should be set for this option:
DjObama
#11254 Post by DjObama » Sat Jan 03, 2026 1:11 pm
RESET_9999 wrote: Fri Jan 02, 2026 7:41 pm install python from the windows store
https://apps.microsoft.com/detail/9pnrb ... n-US&gl=US
Thanks for the tip,I installed python in the Store but unfortunately it doesn't seem to solve this problem. The source file only has one audio track, dts-hd ma, 5.1., it should be easily covertable to ddp, right?
--This workflow will mux any P7 source (BDMV or mkv rip) to DT-DL
  Drag and drop a P7 DV file (BDMV folder/ mpls / or mkv/m2ts/ts) and press enter...
E:\Movies\Pulp.Fiction.1994.mkv
Reading input tracks format/id/language...
Done.
       -    DEMUXING     -
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\DoVi.Scripts\temp.folder18\hdr.hevc'. Container format: HEVC/H.265 elementary stream
Extracting track 1 with the CodecID 'A_DTS' to the file 'D:\DoVi.Scripts\temp.folder18\Pulp.Fiction.1994.track_2_eng.dts'. Container format: Digital Theater System (DTS)
Extracting track 2 with the CodecID 'S_TEXT/UTF8' to the file 'D:\DoVi.Scripts\temp.folder18\Pulp.Fiction.1994.track_3_eng.srt'. Container format: SRT text subtitles
Progress: 100%
        - MUXING TO MP4 -
ffmpeg version 2024-02-22-git-76b2bb96b4-full_build-www.gyan.dev Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --pkg-config=pkgconf --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-dxva2 --enable-d3d11va --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      58. 39.100 / 58. 39.100
  libavcodec     60. 40.100 / 60. 40.100
  libavformat    60. 21.101 / 60. 21.101
  libavdevice    60.  4.100 / 60.  4.100
  libavfilter     9. 17.100 /  9. 17.100
  libswscale      7.  6.100 /  7.  6.100
  libswresample   4. 13.100 /  4. 13.100
  libpostproc    57.  4.100 / 57.  4.100
Input #0, dts, from 'D:\DoVi.Scripts\temp.folder18\Pulp.Fiction.1994.track_2_eng.dts':
  Duration: N/A, start: 0.000000, bitrate: N/A
  Stream #0:0: Audio: dts (dca) (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (dts (dca) -> eac3 (native))
Press [q] to stop, [?] for help
Output #0, matroska, to 'D:\DoVi.Scripts\temp.folder18\EC32.mkv':
  Metadata:
    encoder         : Lavf60.21.101
  Stream #0:0: Audio: eac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), fltp, 1024 kb/s
      Metadata:
        encoder         : Lavc60.40.100 eac3
[out#0/matroska @ 00000197933e39c0] video:0KiB audio:1158836KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 0.177044%
size= 1160888KiB time=02:34:30.68 bitrate=1025.8kbits/s speed= 118x
Extracting track 0 with the CodecID 'A_EAC3' to the file 'D:\DoVi.Scripts\temp.folder18\lossy2.ec3'. Container format: Dolby Digital Plus (E-AC-3)
Progress: 100%
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
[mp4 @ 00000209af09ea00] track 0: codec frame size is not set
Output #0, mp4, to 'D:\DoVi.Scripts\temp.folder18\lossless2.mp4':
  Metadata:
  Stream #0:0: Audio: dts (DTS-HD MA) (mp4a / 0x6134706D), 48000 Hz, 5.1(side), s32p (24 bit)
[out#0/mp4 @ 00000209af0956c0] video:0KiB audio:4391975KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 0.079083%
size= 4395448KiB time=02:34:30.68 bitrate=3884.0kbits/s speed= 524x
 Muxing into a DoVi MP4 file. Be patient, it can take a while. 40min+ on slow HDD
[1/3] Parsing track "F:\Filmy\Pulp.Fiction.1994_BL.hevc"...
hevc: ******************** 100%
[2/3] Parsing track "F:\Filmy\Pulp.Fiction.1994_EL.hevc"...
[3/3] Saving output file(s) "D:\DoVi.Scripts\temp.folder18\temp.mp4"...
written: ******************** 100%
[iso file] dvcC reserved bytes are not zero
IsoMedia import temp.mp4 - track ID 1 - Video (size 3840 x 2160)
IsoMedia import temp.mp4 - track ID 2 - Video (size 1920 x 1080)
[H263Dmx] garbage before first frame!
Cannot find track ID matching fragment #audio
Error importing D:\DoVi.Scripts\temp.folder18\lossy2.ec3#audio:lang=eng:name=DDP: At least one required element has not been found
Deleting TEMP folder...
Start time: 13:43:41,11
End time: 14:04:12,59
Time taken: 0:20:31
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
#11255 Post by RESET_9999 » Sat Jan 03, 2026 2:00 pm
what it does is written in the image you posted
yes it does. look again
#11256 Post by RESET_9999 » Sat Jan 03, 2026 2:09 pm
DjObama wrote: Sat Jan 03, 2026 1:11 pm Thanks for the tip,I installed python in the Store but unfortunately it doesn't seem to solve this problem. The source file only has one audio track, dts-hd ma, 5.1., it should be easily covertable to ddp, right?
I don't know , works fine here. There might be something wrong with your rip
from your log:
''[H263Dmx] garbage before first frame!''
7.1 DDP
5.1 DDP
deadchip12
#11257 Post by deadchip12 » Sun Jan 04, 2026 2:20 am
RESET_9999 wrote: Sat Jan 03, 2026 2:00 pm
I read that but don't know what that means. If I only choose the 4k options then the 1080p display mode wont be allowed to be used?
It only mentions "Passthrough output device", not "Audio output device". Two separate settings.
#11258 Post by RESET_9999 » Sun Jan 04, 2026 3:55 am
If you want 1080p content to be upscaled by the TV, you must set the Kodi GUI to 1080p. The whitelist does not override this behavior; it only informs the player which display modes your TV supports.
That's the setting you're asking...
deadchip12
#11259 Post by deadchip12 » Sun Jan 04, 2026 4:18 am
RESET_9999 wrote: Sun Jan 04, 2026 3:55 am
What happens if I don't choose anything in that whitelist? That's what I did before.
They are 2 separate settings. This is "Audio output device":
If you scroll down, you'll see "Passthrough output device":
#11260 Post by RESET_9999 » Sun Jan 04, 2026 4:56 am
I use the same for both
try playing 25fps content and find out if your TV switches to 50Hz instead of 25Hz
safariff
#11261 Post by safariff » Wed Jan 07, 2026 11:34 pm
RESET_9999 wrote: Thu Jan 01, 2026 12:15 am
Can LG resolve these G5 issues you've pointed out through firmware updates at all?
they can but they wont.
Well that's unfortunate, might have to look at Sony rather than LG for my next OLED (C8 getting a bit outdated for my liking)
Anyone know of a way to get ffmpeg or another tool show the ICtCp colorspace on a video file (I am just wondering if I have a potential p5 file with the wrong colorspace)?
I got close with ffmpeg:
ffprobe -v error -select_streams v:0 -show_entries stream=color_space,color_transfer,color_primaries,pix_fmt -of default=nw=1 video.mkv
DV8file:
pix_fmt=yuv420p10le
color_space=bt2020nc
color_transfer=smpte2084
color_primaries=bt2020
DV5file:
pix_fmt=yuv420p10le
color_space=unknown
color_transfer=unknown
color_primaries=unknown
darrrkmanxxx
#11262 Post by darrrkmanxxx » Sun Jan 11, 2026 12:24 pm
Guys do you know by chance if the avdvplus builds are supported with Dune HD Pro Vision 4K (S905X4-J). I'm currently on CPM A14
Trees
#11263 Post by Trees » Wed Jan 14, 2026 11:24 pm
Reset, how do you get the below player process information?
I followed your CE guide and keymap tutorial but all I get is the basic Kodi PPI? Without the DV type real time luminance data... I am on https://github.com/avdvplus/Builds/rele ... vdvplus_R5.
Thank you for doing all of this man, the information you share is worth gold to us HDR enthusiasts!
#11264 Post by RESET_9999 » Thu Jan 15, 2026 2:14 am
Trees
#11265 Post by Trees » Thu Jan 15, 2026 6:34 am
RESET_9999 wrote: Thu Jan 15, 2026 2:14 am you need one of the custom skins
https://discourse.coreelec.org/t/severa ... ilds/53514
Thank you. Damn, all of the links seem to be dead, are there any other live links that you know of, specifically for Arctic Zephyr?
