PM sent.AviTMC wrote: Fri Jan 02, 2026 3:13 amThank you, Cooper, for the guidance. Please see below:Coopervid wrote: Wed Dec 31, 2025 8:48 pmYou need to install Makemkv and run it. It will show then the information you should post.AviTMC wrote: Wed Dec 31, 2025 4:38 am Hi Cooper,
I have both Pioneer BDR-209D and BDR-209M drives. My OS on both computers is Windows 10, but for some reason I cannot access the System Information of the optical drives. I tried both Device Manager and System Information. The details of the drives are not showing on the right pane of each window. Any assistance is greatly appreciated. I'm trying to get you the drive information of both drives, so I can see if I can flash them.
Thank you, sir.
OS device name: G:
Current profile: DVD+R
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.30
Serial number: NKDL080890WL
Firmware date: 2014-12-05
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.30/ID61
Pioneer bdr 209 and Pioneer bdr 209m
Re: Pioneer bdr 209 and Pioneer bdr 209m
PM sent.kinimato wrote: Fri Jan 02, 2026 8:52 am Hey @Coopervid,
I would also appreciate some help with this drive I have. It's a Pioneer BDR-S09. Please advise if this is UHD capable.
Product: BD-RW BDR-S09
Revision: 1.34
Serial number: QGDL018666CN
Firmware date: 2016-04-25
Highest AACS version: 76
Firmware version: 1.34/ID43
Thanks for all your help!
Hey Coopervid, I got the following message: "Drive and firmware hardware types don't match". Any ideas? This is an internal drive by the way.
Here is the information again, and also what BDRflash is providing, just in case.
Revision: 1.34
This if the BDRflash Device Information
General Information
Model name: PIONEER BD-RW BDR-S09
Extra information: 16/04/25 PIONEER
Buffer size: 4000 kiB
Loader type: Tray
Interface type: Serial ATAPI
Additional Information
Product code:BDR-S09XLB
Manufactured: July 2017
Product origin: China
Hardware type: SAT 8600
Kernel type: ID43
Firmware type: ID43
Kernel version: 0000
Thanks again!
Revision: 1.34
General Information
Loader type: Tray
Kernel type: ID43
Firmware type: ID43
Thanks again!
I spun the Buffalo BRXL-16U3 wheel and also landed myself a Pioneer drive
OS device name: E:
Product: BD-RW BDR-209M
Revision: 8.53
Serial number: [redacted]
Firmware date: 2019-03-07
Drive platform: RS8F00
Firmware version: 8.53/ID52
I have 2 UHD Blu Rays ready for testing. Please hook me up with that custom UHD firmware!
OS device name: E:
Revision: 8.53
undusted2657
Hello @Coopervid!
I would also very much appreciate if you could let me know if this drive is UHD capable:
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 1.30
Serial number: OEDL...
Thanks very much!
Revision: 1.30
Thanks very much!
just email me that drive info see below it can do UHD once flashedSpinCity wrote: Fri Jan 02, 2026 10:26 pm I spun the Buffalo BRXL-16U3 wheel and also landed myself a Pioneer drive
OS device name: E:
Revision: 8.53
Check the force flash box.kinimato wrote: Fri Jan 02, 2026 9:42 pm Hey Coopervid, I got the following message: "Drive and firmware hardware types don't match". Any ideas? This is an internal drive by the way.
Revision: 1.34
General Information
Loader type: Tray
Kernel type: ID43
Firmware type: ID43
Thanks again!
Dragonnova
Now i have the two drives:Coopervid wrote: Mon Sep 15, 2025 9:15 amYour decision. The Pioneer will rip hard to read discs while thr BU40 will rip faster when there is no problem to read the disc. 209 can be flashed to read UHDs as well. I personally would go with the Pioneers and flash both for UHD.Dragonnova wrote: Sun Sep 14, 2025 10:21 am Is it better to have two Pioneer BDR 209-DBKs or one Pioneer BDR 209-DBK and one LG BU40N? I have a limited budget and have to decide between one of these two options.
Laufwerksinformation
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.50
Serienummer:
Firmware-Datum: 2017-12-21
Markierungen der Bus-Verschlüsselung: 13
Drive platform: RS8601
Firmware version: 1.50/ID61
Produzent: PIONEER
Revision: 1.34
Serienummer:
Firmware-Datum: 2016-04-25
Firmware version: 1.34/ID61
PM sent.Dragonnova wrote: Sat Jan 03, 2026 5:39 pmNow i have the two drives:Coopervid wrote: Mon Sep 15, 2025 9:15 amYour decision. The Pioneer will rip hard to read discs while thr BU40 will rip faster when there is no problem to read the disc. 209 can be flashed to read UHDs as well. I personally would go with the Pioneers and flash both for UHD.Dragonnova wrote: Sun Sep 14, 2025 10:21 am Is it better to have two Pioneer BDR 209-DBKs or one Pioneer BDR 209-DBK and one LG BU40N? I have a limited budget and have to decide between one of these two options.
Produzent: PIONEER
Revision: 1.50
Serienummer:
Produzent: PIONEER
Revision: 1.34
Serienummer:
phantom0308
Coopervid, sorry to trouble you again, there is another BDR-X09 i have already buy. can you send me the firmware? thanks a lot!
OS device name: E:
Product: BD-RW BDR-X09
Revision: 1.00
Serial number: "
Highest AACS version: 82
Firmware version: 1.34/ID60
danieduardo88
Hey!
I emailed Billycar directly already but wasn't sure if I should've posted here first. I saw these drives could possibly be flashed for UHD Blu-ray ripping in the makemkv forms. I have a BU40N, but even after cleaning it stopped reading blu-rays in general. I remembered I had the BDR-208D laying around and it works perfectly(used a handful of times). So is it possible for 4K Blu-rays? Here are the specs from makemkv:
Manufacture date: March 2013
OS device name: E:
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: XXXXXXXXXXXX
Firmware date: 2012-08-22
Highest AACS version: 38
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
OS device name: E:
Revision: 1.10
Hi!
I would like to enable UHD with my BDR209M as well. Thank you very much.
OS device name: /dev/sr1
Revision: 1.34
Serial number: <redacted>
No disc insertedRe: Pioneer bdr 209 and Pioneer bdr 209m
PM sent.nibbs wrote: Thu Jan 08, 2026 11:48 am Hi!
Drive Information OS device name: /dev/sr1 Manufacturer: PIONEER Product: BD-RW BDR-209M Revision: 1.34 Serial number: <redacted> Firmware date: 2016-04-25 Bus encryption flags: 13 Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.34/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
I'm trying to convert my BDR-209M to a LibreDrive, but I can't find the file. Thank you in advance.
OS Device Name: E:
Current Profile: BD-ROM
Product Name: BD-RW BDR-209M
Version: 1.50
Serial Number: SADL002513WL
Firmware Release Date: 2017-12-21
Bus Encryption Flag: 1B
Highest AACS Version: 82
Drive Platform: Pioneer RS8601
Firmware Version: ID20
No Disc
OS Device Name: E:
Version: 1.50
No Disc
PM sent.tanba7000 wrote: Sat Jan 10, 2026 4:00 pm I'm trying to convert my BDR-209M to a LibreDrive, but I can't find the file. Thank you in advance.
OS Device Name: E:
Version: 1.50
No Disc
