Pioneer bdr 209 and Pioneer bdr 209m
Re: Pioneer bdr 209 and Pioneer bdr 209m
AviTMC wrote: Fri Jan 02, 2026 3:13 am
Coopervid wrote: Wed Dec 31, 2025 8:48 pm
AviTMC wrote: Wed Dec 31, 2025 4:38 am Hi Cooper,
I have both Pioneer BDR-209D and BDR-209M drives. My OS on both computers is Windows 10, but for some reason I cannot access the System Information of the optical drives. I tried both Device Manager and System Information. The details of the drives are not showing on the right pane of each window. Any assistance is greatly appreciated. I'm trying to get you the drive information of both drives, so I can see if I can flash them.
Thank you, sir.
You need to install Makemkv and run it. It will show then the information you should post.
Thank you, Cooper, for the guidance. Please see below:
OS device name: G:
Current profile: DVD+R
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.30
Serial number: NKDL080890WL
Firmware date: 2014-12-05
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.30/ID61
PM sent.
kinimato wrote: Fri Jan 02, 2026 8:52 am Hey @Coopervid,
I would also appreciate some help with this drive I have. It's a Pioneer BDR-S09. Please advise if this is UHD capable.
Product: BD-RW BDR-S09
Revision: 1.34
Serial number: QGDL018666CN
Firmware date: 2016-04-25
Highest AACS version: 76
Firmware version: 1.34/ID43
Thanks for all your help!
PM sent.
kinimato
Post by kinimato »
Hey Coopervid, I got the following message: "Drive and firmware hardware types don't match". Any ideas? This is an internal drive by the way.
Here is the information again, and also what BDRflash is providing, just in case.
Revision: 1.34
This if the BDRflash Device Information
General Information
Model name: PIONEER BD-RW BDR-S09
Extra information: 16/04/25 PIONEER
Buffer size: 4000 kiB
Loader type: Tray
Interface type: Serial ATAPI
Additional Information
Product code:BDR-S09XLB
Manufactured: July 2017
Product origin: China
Hardware type: SAT 8600
Kernel type: ID43
Firmware type: ID43
Kernel version: 0000
Thanks again!
SpinCity
Post by SpinCity »
I spun the Buffalo BRXL-16U3 wheel and also landed myself a Pioneer drive :D
OS device name: E:
Product: BD-RW BDR-209M
Revision: 8.53
Serial number: [redacted]
Firmware date: 2019-03-07
Drive platform: RS8F00
Firmware version: 8.53/ID52
I have 2 UHD Blu Rays ready for testing. Please hook me up with that custom UHD firmware!
undusted2657
Post by undusted2657 »
Hello @Coopervid!
I would also very much appreciate if you could let me know if this drive is UHD capable:
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 1.30
Serial number: OEDL...
Thanks very much!
SpinCity wrote: Fri Jan 02, 2026 10:26 pm I spun the Buffalo BRXL-16U3 wheel and also landed myself a Pioneer drive :D
OS device name: E:
Revision: 8.53
just email me that drive info see below it can do UHD once flashed
kinimato wrote: Fri Jan 02, 2026 9:42 pm Hey Coopervid, I got the following message: "Drive and firmware hardware types don't match". Any ideas? This is an internal drive by the way.
Revision: 1.34
General Information
Loader type: Tray
Kernel type: ID43
Firmware type: ID43
Thanks again!
Check the force flash box.
Dragonnova
Post by Dragonnova »
Coopervid wrote: Mon Sep 15, 2025 9:15 am
Dragonnova wrote: Sun Sep 14, 2025 10:21 am Is it better to have two Pioneer BDR 209-DBKs or one Pioneer BDR 209-DBK and one LG BU40N? I have a limited budget and have to decide between one of these two options.
Your decision. The Pioneer will rip hard to read discs while thr BU40 will rip faster when there is no problem to read the disc. 209 can be flashed to read UHDs as well. I personally would go with the Pioneers and flash both for UHD.
Now i have the two drives:
Laufwerksinformation
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.50
Serienummer:
Firmware-Datum: 2017-12-21
Markierungen der Bus-Verschlüsselung: 13
Drive platform: RS8601
Firmware version: 1.50/ID61
Produzent: PIONEER
Revision: 1.34
Serienummer:
Firmware-Datum: 2016-04-25
Firmware version: 1.34/ID61
Dragonnova wrote: Sat Jan 03, 2026 5:39 pm
Produzent: PIONEER
Revision: 1.50
Serienummer:
Produzent: PIONEER
Revision: 1.34
Serienummer:
PM sent.
phantom0308
Post by phantom0308 »
Coopervid wrote: Sun Jan 04, 2026 11:05 am PM sent.
Coopervid, sorry to trouble you again, there is another BDR-X09 i have already buy. can you send me the firmware? thanks a lot!
OS device name: E:
Product: BD-RW BDR-X09
Revision: 1.00
Serial number: "
Highest AACS version: 82
Firmware version: 1.34/ID60
danieduardo88
Post by danieduardo88 »
Hey!
I emailed Billycar directly already but wasn't sure if I should've posted here first. I saw these drives could possibly be flashed for UHD Blu-ray ripping in the makemkv forms. I have a BU40N, but even after cleaning it stopped reading blu-rays in general. I remembered I had the BDR-208D laying around and it works perfectly(used a handful of times). So is it possible for 4K Blu-rays? Here are the specs from makemkv:
Manufacture date: March 2013
OS device name: E:
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: XXXXXXXXXXXX
Firmware date: 2012-08-22
Highest AACS version: 38
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
nibbs
Post by nibbs »
Hi!
I would like to enable UHD with my BDR209M as well. Thank you very much.
OS device name: /dev/sr1
Revision: 1.34
Serial number: <redacted>
nibbs wrote: Thu Jan 08, 2026 11:48 am Hi!
Revision: 1.34
PM sent.
tanba7000
Post by tanba7000 »
I'm trying to convert my BDR-209M to a LibreDrive, but I can't find the file. Thank you in advance.
OS Device Name: E:
Current Profile: BD-ROM
Product Name: BD-RW BDR-209M
Version: 1.50
Serial Number: SADL002513WL
Firmware Release Date: 2017-12-21
Bus Encryption Flag: 1B
Highest AACS Version: 82
Drive Platform: Pioneer RS8601
Firmware Version: ID20
No Disc
tanba7000 wrote: Sat Jan 10, 2026 4:00 pm I'm trying to convert my BDR-209M to a LibreDrive, but I can't find the file. Thank you in advance.
OS Device Name: E:
Version: 1.50
No Disc
PM sent.
