ASUS BW-16D1X-U - Flashable?
kscrib
Re: ASUS BW-16D1X-U - Flashable?
#241 Post by kscrib » Mon Dec 29, 2025 7:09 pm
MartyMcNuts wrote: Mon Dec 29, 2025 4:11 am
kscrib wrote: Sun Dec 28, 2025 7:05 pm I see others list this drive, but I am missing the line "Highest AACS version." Is this drive flashable? If it makes a difference, I use the drive on an Ubuntu system, and only have it on Windows to flash it. I have SPFtool flasher and All you need firmware pack
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Yep, flash to WH16NS60 1.02-MK and you are good to go.
That worked. Thank you for all you efforts and support. I see you have helped a LOT of people. Thank you for that!
ipefix
#242 Post by ipefix » Fri Jan 02, 2026 4:23 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Hello, I don't find the firmware WH16NS60 1.02-MK, have you a link to download it ?
#243 Post by Coopervid » Fri Jan 02, 2026 4:31 pm
ipefix wrote: Fri Jan 02, 2026 4:23 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Here is a link for SDFTool flasher and the All you need firmware pack.
viewtopic.php?f=16&t=22896&hilit=sdftool
ipefix
#244 Post by ipefix » Fri Jan 02, 2026 4:50 pm
Coopervid wrote: Fri Jan 02, 2026 4:31 pm
Thank you , I downloaded DE_LG_WH16NS60_1.02_MK.bin, flash the firmware and I have this error
Command produced error code 0x82062900
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: XXXXXXXXXXX
Capture d'écran 2026-01-02 174724.png (4.94 KiB) Viewed 23594 times
#245 Post by Coopervid » Fri Jan 02, 2026 4:51 pm
ipefix wrote: Fri Jan 02, 2026 4:50 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Make sure no disc in drive and tray is closed.
ipefix
#246 Post by ipefix » Fri Jan 02, 2026 11:07 pm
Coopervid wrote: Fri Jan 02, 2026 4:51 pm
Well done, the drive wasn't empty, thank you so much
Bouchmil
#247 Post by Bouchmil » Sat Jan 03, 2026 6:16 pm
Hello! I just bought this Asus drive with the Pioneer platform, can someone help me flash it to enable UHD? Here is the full information form make mkv below:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Firmware date: 2020-07-21
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: E113/ID76
#248 Post by Billycar11 » Sun Jan 04, 2026 12:09 am
Bouchmil wrote: Sat Jan 03, 2026 6:16 pm Hello! I just bought this Asus drive with the Pioneer platform, can someone help me flash it to enable UHD? Here is the full information form make mkv below:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
email me that drive info see below
BaumTrustking
#249 Post by BaumTrustking » Fri Jan 09, 2026 12:44 pm
Hello everyone, I bought this drive, can anyone help me with flashing it?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Serienummer: DIDL128062WL
Firmware-Datum: 2020-07-21
Highest AACS version: 82
Firmware version: E116/ID71
Justin_4321
#250 Post by Justin_4321 » Fri Jan 09, 2026 8:33 pm
I just got this drive, could i get some help flashing it.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL127730WL
#251 Post by Coopervid » Sat Jan 10, 2026 2:42 pm
Justin_4321 wrote: Fri Jan 09, 2026 8:33 pm I just got this drive, could i get some help flashing it.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
arrrrgbee
#252 Post by arrrrgbee » Sat Jan 10, 2026 10:45 pm
Throwing my hat into this pile.
Hoping to confirm instructions and process for flashing::
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: <RandomThing>
Highest AACS version: 72
I assume i just grab the All You Need Firmware Pack (MartyMcNuts).zip or the https://drive.google.com/file/d/1HRnbXi ... 0FCdM/view
And follow the ultimate guide?
viewtopic.php?f=16&t=19634
and i'm hopefully not special?
Feel free to tell me that i'm special and needing percussive correction, would be nice to not brick this drive although i have no issues with getting an actual good reader
#253 Post by MartyMcNuts » Sat Jan 10, 2026 11:29 pm
arrrrgbee wrote: Sat Jan 10, 2026 10:45 pm Throwing my hat into this pile.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Yep, it's a LG drive. You can flash it directly to WH16NS60 1.02-MK, which is the recommended firmware.
Assirock
#254 Post by Assirock » Mon Jan 12, 2026 8:46 pm
Has anyone removed the drive from an Asus bw-16d1x-u to install in a desktop? Looks like its glued together.
What file should I use? Thank you.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware version: ID76
BaumTrustking
#255 Post by BaumTrustking » Tue Jan 13, 2026 1:08 pm
Can someone please help me.
BaumTrustking wrote: Fri Jan 09, 2026 12:44 pm Hello everyone, I bought this drive, can anyone help me with flashing it?
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
