Original Firmware for Asus BW-16D1X-U (A105)
rawlinc
Post by rawlinc »
A couple questions about this drive:
  • Does anybody have the original firmware for this variant of the Asus BW-16D1X-U (see info below)? I'm not sure if I'm comfortable flashing the drive to make it LibreDrive compatible if there is no way to get it back to the original firmware version (for warranty purposes, etc). I looked at the firmware dump from both MakeMKV and the the GUI SDF tool but they don't appear to be full firmware dumps as they are much smaller than some of the firmware files from the firmware packs listed on the forums.
  • Other threads say that flashing the WH16NS60 1.02-MK firmware works on this exact model but the flashing guide recommends against cross flashing. Is it also possible to flash the ASUS-BW-16D1HT-3.10 firmware and would that be preferred over flashing the LG firmware.
  • Does anybody know how to open the enclosures for the Asus BW-16D1X-U? I don't see any obvious ways to non-destructively open the enclosure to look at the original label on the 5.25" drive inside.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: <removed>
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Re: Original Firmware for Asus BW-16D1X-U (A105)
rawlinc wrote: Thu Jan 01, 2026 9:41 pm A couple questions about this drive:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
1. No, we don't have the original firmware.
2. For all encrypted firmware (dated 2020+) only the cal data is dumped.
3. The guide recommends against cross-flashing slim drive firmware to a desktop drive and vice-versa. It is fine to cross-flash desktop drive firmware to desktop drive.
4. You could use either the BW-16D1HT 3.10-MK or WH16NS60 1.02-MK firmware. The latter does read faster and removes the UHD disc sleep bug.
5. No idea how to open it. Check under the feet for screws? Or do some google-fu!
