SDFtools
greerc24
SDFtools
#1 Post by greerc24 » Tue Dec 30, 2025 11:38 pm
I must be doing something wrong.
I wanted a dump of FW on a LG drive and could not figure out how to get it.
I tried SDFtool Flasher (v1.36 and v1.35) and get a cannot flash error while doing a READ.
It says I cannot flash the drive due to a MT1959 error.
But when i use sdftool_flasher.zip and a READ it says creating FW dump but I cannot find it.
I also have it creating FW dump automagicaly on another drive.
Re: SDFtools
#2 Post by Woodstock » Wed Dec 31, 2025 12:20 am
Are you properly selecting whether the firmware is encrypted or not?
Re: SDFtools
#3 Post by MartyMcNuts » Wed Dec 31, 2025 2:09 am
greerc24 wrote: Tue Dec 30, 2025 11:38 pm I must be doing something wrong.
Unless the firmware is (unencrypted) pre 2020, SDFtool cannot dump the full firmware. It only dumps the cal data. Also, this is only compatibale with the MT1959 drive platform.
Post your MakeMKV drive info and libredrive info sections if you want more help.
greerc24
Re: SDFtools
#4 Post by greerc24 » Thu Jan 01, 2026 12:08 am
The firmware is from an LG drve that pre 2020. (HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_K27841F1801)
It auto read it and I sent it in.
The error is : The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed.
This the case of just trying to read it, not flash it. SDFTools is selecting it, based on something, and never even lets me choose.
ANYways it just a READ.
Re: SDFtools
#5 Post by MartyMcNuts » Thu Jan 01, 2026 9:53 pm
greerc24 wrote: Thu Jan 01, 2026 12:08 am The firmware is from an LG drve that pre 2020. (HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_K27841F1801)
SDFtool Flasher checks the drive platform when a drive is slelected and is only compatible with drives containing the MT1959 drive platform. Your GGC-H20L is way, way older (I had one back in 2008) with the wrong drive platform and is not compatible with this tool.
I'm not sure what you are hoping for but it will never be able to read UHD discs.
