Troubles ripping Elephant (2003)
mcmehrtens
Post by mcmehrtens »
I'm trying to rip the R1 America - HBO DVD release of Elephant (2003).
Each time I open the disc in MakeMKV, it takes several hours to load the titles, during which the CSS sectors steadily counts up into the millions. Depending on the DVD structure protection removal method used, I sometimes get past the opening process to the point where I can rip four titles, one of which is the main feature.
Once I start to save the titles, however, MakeMKV successfully rips the three non-main feature titles (HBO title slides, etc.) and immediately fails to rip the main feature. Trying to rip just the main feature also results in immediate failure. Here is the log file:
Debug log started at Wed Dec 31 21:41:55 2025 , written by MakeMKV v1.18.2 darwin(arm64-release)
001005:0000 MakeMKV v1.18.2 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/mcmehrtens/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.67.1 (x86_64-apple-darwin25.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE  WH16NS60 1.02 KLUN4DA0254d" opened in OS access mode.
003338:0000 Downloading latest SDF to /Users/mcmehrtens/Library/MakeMKV ...
SDF  v0a4: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLUN4DA0254
001003:0020 DEBUG: Code 0 at ,~+[%E+HI&A$iAZ4dy;<WPJoE:29395149
DEBUG: Code 0 at Pid,q~1EKu!Tod|Ry}]3iR,<&:29394367
001011:0000 Using LibreDrive mode (v06.3 id=7FA2657C7667)
DEBUG: Code 2 at {WOf^PqOTlWjI_,n2:121263199
DEBUG: Code 3 at {WOf^PqOTlWjI_,n2:121263199
DEBUG: Code 4 at {WOf^PqOTlWjI_,n2:121263199
DEBUG: Code 6 at {WOf^PqOTlWjI_,n2:121263199
003038:0000 Cells 20-20 were removed from title end
003028:0000 Title #1 was added (19 cell(s), 1:21:14)
003028:0000 Title #2 was added (19 cell(s), 1:21:14)
003038:0000 Cells 2-2 were removed from title end
003028:0000 Title #3 was added (1 cell(s), 0:00:09)
003028:0000 Title #4 was added (1 cell(s), 0:00:09)
003028:0000 Title #5 was added (1 cell(s), 0:00:16)
Title skip vts=1 pgcn=1
Title skip vts=6 pgcn=2
001003:0020 DEBUG: Code 5 at (nm/a&2My+x2m:29395770
001003:0020 DEBUG: Code 5 at D(O(v-)QwLA4'w3=mX:121272882
001003:0020 DEBUG: Code 0 at w5Ax5G:`w,]rt%SM:213142036
001003:0020 DEBUG: Code 0 at w5Ax5G:`w,]rt%SM:29397978
001003:0020 DEBUG: Code 2 at U;|wYq1 RVUx&dD0:121262578
001003:0020 DEBUG: Code 0 at v.3;9nKis;k%gg]:213138494
001003:0020 DEBUG: Code 0 at .t~*D%9eRpS}9*:213134676
001003:0020 DEBUG: Code 0 at U;|wYq1 RVUx&dD0:121262578
Launching /Applications/MakeMKV.app/Contents/MacOS/mmgplsrv
DEBUG: Code 0 at 0WlR+T>f@FT?Zj*w,Uaf:29396460
003028:0000 Title #1 was added (20 cell(s), 1:21:14)
003028:0000 Title #2 was added (20 cell(s), 1:21:14)
003028:0000 Title #3 was added (2 cell(s), 0:00:09)
003028:0000 Title #5 was added (2 cell(s), 0:00:16)
003026:0000 Title #7 declared length is 0:00:00 while its real length is 0:00:01 - assuming fake title
001003:0020 DEBUG: Code 0 at w5Ax5G:`w,]rt%SM:213142335
001003:0020 DEBUG: Code 0 at D(O(v-)QwLA4'w3=mX:121246110
001003:0020 DEBUG: Code 6 at (nm/a&2My+x2m:29395770
001003:0020 DEBUG: Code 6 at D(O(v-)QwLA4'w3=mX:121272882
005014:0000 Saving 4 titles into directory file:///Users/mcmehrtens/Movies/Elephant (2003) [tmdbid-1807]
001003:0020 DEBUG: Code 0 at ,PR2au|#szKdAcbG%SN:121265223
001003:0020 DEBUG: Code 0 at y7qD&er_;r8qO|@>eocZ:29395793
001003:0020 DEBUG: Code 0 at @#EcP+"MLXli_{7d_']:29393562
001003:0020 DEBUG: Code 0 at y7qD&er_;r8qO|@>eocZ:213131157
001003:0020 DEBUG: Code 0 at y7qD&er_;r8qO|@>eocZ:121262647
001003:0020 DEBUG: Code 22 at y7qD&er_;r8qO|@>eocZ:121261773
001003:0020 DEBUG: Code 0 at <]H%`%b[f5dKng`jH'Q4D7:121263751
001003:0020 DEBUG: Code 0 at !;A$,l"%cXgG@RkHo'O>0:121268972
001003:0020 DEBUG: Code 0 at QQV'fPN/U$<NJ(_L4':M:29394022
001003:0020 DEBUG: Code 0 at QQV'fPN/U$<NJ(_L4':M:121266764
001003:0020 DEBUG: Code 0 at !;A$,l"%cXgG@RkHo'O>0:213136907
001003:0020 DEBUG: Code 0 at !;A$,l"%cXgG@RkHo'O>0:121268604
001003:0020 DEBUG: Code 0 at &j%;w<'hHq}RbG$#tP1:29394482
001003:0020 DEBUG: Code 0 at &j%;w<'hHq}RbG$#tP1:121264740
001003:0020 DEBUG: Code 0 at &j%;w<'hHq}RbG$#tP1:29396138
001003:0020 DEBUG: Code 0 at &j%;w<'hHq}RbG$#tP1:213134906
001003:0020 DEBUG: Code 0 at N<S7[juctTkYCk4w:213130904
001003:0020 DEBUG: Code 0 at N<S7[juctTkYCk4w:213130582
001003:0020 DEBUG: Code 0 at h9r!sG 8D?e6!73F9@:121269731
001003:0020 DEBUG: Code 0 at h9r!sG 8D?e6!73F9@:29401819
005003:0000 Failed to save title 0 to file /Users/mcmehrtens/Movies/Elephant (2003) [tmdbid-1807]/B1_t00.mkv
005004:0080 3 titles saved, 1 failed
005037:0204 Copy complete. 3 titles saved, 1 failed.
005014:0000 Saving 1 titles into directory file:///Users/mcmehrtens/Movies/Elephant (2003) [tmdbid-1807]
005004:0080 0 titles saved, 1 failed
  • I've tried using the four different DVD structure protection removal methods (Auto, CellWalk, CellTrim, CellFull) with no success. Although IIRC, some of the methods did not properly identify the main feature.
  • I've cleaned the disc thoroughly.
  • On a long shot, I tried following the suggestion of a different user on this forum and tried ripping the movie while having it open in VLC... that didn't work.
  • I'm using an ASUS Blu-ray drive that I've successfully used to rip dozens of other Blu-ray 4K UHD discs, Blu-ray Discs, and DVDs before and after attempting Elephant (2003).
  • Here is some debug info from MakeMKV:
OS device name: /dev/rdisk4
Current profile: DVD+R DL
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLUN4DA0254
Highest AACS version: 81
Firmware version: 1.02
Disc Information
Label: ELEPHANT
Timestamp: 2015-01-29 14:40:38
Data capacity: 7.43 Gb
Disc type: DVD-ROM
Disc size: 120mm
Number of layers: 2 (OTP)
Let me know if I need to provide any further information. Any assistance would be greatly appreciated :)
mcmehrtens
Re: Troubles ripping Elephant (2003)
  • I tried creating a backup of the DVD as well. The backup hung at ~74 MB, ran for a while longer (maybe about an hour?), and then eventually failed. Log below:
Debug log started at Thu Jan  1 22:50:54 2026 , written by MakeMKV v1.18.2 darwin(arm64-release)
005072:0000 Backing up disc into folder "file:///Users/mcmehrtens/Movies/Elephant (2003) [tmdbid-1807]/ELEPHANT.iso"
001003:0020 DEBUG: Code 0 at IWOfE|E[N?\:/SSR(oS~:121266097
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Fri Jan  2 04:54:21 2026
