Slimline USB WP50NB40 (NB52) flashing failure for MAC OS 26.2
cutler.davidj
#1 Post by cutler.davidj » Wed Dec 31, 2025 5:03 pm
Hi All,
I am trying to flash Slimline USB WP50NB40 (NB52) following the instructions, and it everything appears to work, but the ROM is not flashed.
For instance
sudo bash
./makemkvcon f -l
Returns results :
Found 1 drives(s)
00: /IOBDServices/BC3A153E
HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM2221S02334
./makemkvcon f -d '/IOBDServices/BC3A153E' -f ./sdf.bin rawflash enc -i ./HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
Returns :
Reading input file ./HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
Current Drive ID: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM2221S02334
Using USB chipset workaround for Desktop drive handshake
yes
100% Operation finished
Done successfully]
And then
./makemkvcon f -l
Found 1 drives(s)
Indicating the flash failed.
Does anyone have any idea what I have done wrong?
Cheers,
dave
Re: Slimline USB WP50NB40 (NB52) flashing failure for MAC OS 26.2
#2 Post by Woodstock » Wed Dec 31, 2025 5:07 pm
You didn't mention whether or not you'd powered the drive down to reset it... Without that, the drive is still running its original firmware.
#3 Post by MartyMcNuts » Wed Dec 31, 2025 11:04 pm
cutler.davidj wrote: Wed Dec 31, 2025 5:03 pm Hi All,
For instance
sudo bash
./makemkvcon f -l
Returns results :
Found 1 drives(s)
Returns :
yes
Done successfully]
And then
./makemkvcon f -l
Found 1 drives(s)
Cheers,
dave
Looks like it worked to me. You said you started with a WP50NB40 and have flashed BP50NB40 1.03-MK to it and the drive now reports as a BP50NB40 1.03.
Is this not correct? To be 100% certain, open MakeMKV and see if libredrive is enabled. If so, then the flash has successfully worked.
If it is correct, then the flash has worked. Now you would need to perform the cross-flash to either BP60NB10 or BU40N firmware for UHD compatibility.
cutler.davidj
#4 Post by cutler.davidj » Fri Jan 02, 2026 3:36 pm
Woodstock wrote: Wed Dec 31, 2025 5:07 pm You didn't mention whether or not you'd powered the drive down to reset it... Without that, the drive is still running its original firmware.
AHHHHHH!!!!!!!!!!!!! That was it.
For people's future reference, with all the key files in the current directory:
sudo bash
./makemkvcon f -l
Where '/IOBDServices/BC3A153E' is the location reported by ./makemkvcon f -l
UNPLUG THE DRIVE; LET IT SIT FOR A MINUTE
Replug in
./makemkvcon f -d '/IOBDServices/BC3A153E' -f ./sdf.bin rawflash full -i ./HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Replug in
Launch makemkv enable Libre. Exit makemkv, and restart it.
It was just that simple!!!
Thank you all so much!!!!!!
Cheers,
dave
