'Delivery Man'
mbf199t
'Delivery Man'
#1 Post by mbf199t » Sun Dec 28, 2025 10:43 pm
Hi Guys
Hope everyone had a good Christmas if you celebrate.
I'm an old hand with MakeMKV and encounter very few issues, most of which I've resolved with either a serious disc clean or a replacement disc, but I've hit an actual problematic title (I think).
The affected disk is 'Delivery Man' - disc label EO51767DP. As soon as the initial scan starts (before having retrieved the list of chapters/titles) the process aborts within 23 seconds. The debug log reports:
MakeMKV v1.18.2 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/user/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-XS07 1.01 AFDL003176WLd" opened in OS access mode.
Downloading latest SDF to /Users/user/Library/MakeMKV ...
Using LibreDrive mode (v02.1 id=A470FBFD375E)
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 0 at r8+;sI&bXH(5!l:29400071
IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 0 at !c16[DbCG./o`CQ<<:121262854
I put this down to a faulty disc after some regular troubleshooting, but having sourced a replacement, it generates exactly the same error, which I presume means it's a protection/authoring issue.
Is there anything I can do to make this thing work/gather useful information?
Many thanks!
Re: 'Delivery Man'
#2 Post by dcoke22 » Mon Dec 29, 2025 3:17 pm
You could try the different DVD opening modes.
mbf199t
Re: 'Delivery Man'
#3 Post by mbf199t » Wed Dec 31, 2025 7:57 pm
Thanks. I did try the three different methods via manual selection but it's the exact same outcome every time in the shortest timeframe I've ever seen MakeMKV fail. It takes three seconds from pressing the open disc button to it failing/halting any further scan. Really bizarre.
dcoke22 wrote: Mon Dec 29, 2025 3:17 pm You could try the different DVD opening modes.
mbf199t
Re: 'Delivery Man'
#4 Post by mbf199t » Fri Jan 02, 2026 10:21 pm
Update: Currently trying to backup the DVD using ddrescue (on macOS) to see is MakeMKV will read it from an ISO file. I'll report back - cross your fingers for me!
danjimian
Re: 'Delivery Man'
#5 Post by danjimian » Tue Feb 24, 2026 1:42 pm
Hi, I'm having the same issue with this disc. It's the first disc in 10 years that I've not been able to rip. I've also sourced a second copy and had the same issue. Any hints as to how you eventually managed it (assuming you did) would be gratefully received.
