Is my pioneer BDR-XD05s flashable?
Re: Is my pioneer BDR-XD05s flashable?
Hello, I have a BDRxd05s and would like to know if it's flashable for uhd. Thanks in advance!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: QDXXXXXXXXX
Firmware date: 2017-06-22
Highest AACS version: 66
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
OS device name: E:
Revision: 3.10
PM sent.vandon wrote: Wed Dec 31, 2025 7:05 pm Hello, I have a BDRxd05s and would like to know if it's flashable for uhd. Thanks in advance!
OS device name: E:
Revision: 3.10
Hello!
I too have a BDR-XD05 I'd like to flash if possible. Forutnately I'd not been keeping it's firmware up to date. Details:
Any help appreciated!
OS device name: H:
Revision: 1.10
Serial number: MFDL<REDACTED>
Firmware date: 2013-04-24
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8231
Firmware version: 1.10
Unrestricted read speed: YesThanks!
PM sent.Razor68 wrote: Sun Jan 04, 2026 7:30 pm Hello!
Any help appreciated!Code: Select all
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 1.10 Serial number: MFDL<REDACTED> Firmware date: 2013-04-24 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 1.10 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Can someone help me identofy if my drive is flashable? Thank you!
Revision: 3.10
Serial number:
Revision: 3.10
Serial number:
yes its flashable to read UHD email me that drive info section see belowatlas247 wrote: Mon Jan 12, 2026 10:38 pm Can someone help me identofy if my drive is flashable? Thank you!
Revision: 3.10
Serial number:
DoggyDogDog
Good day, I was wondering if my BD Drive (BDR-XD05s) is flashable for UHD and what needs to be done:
Thank you.
OS device name: I:
Revision: 3.01
Serial number: -----------
Firmware date: 2014-12-26
Highest AACS version: 19
Firmware version: 3.01/ID34
Unrestricted read speed: Yes-
Yes if you want it to do UHD email me that drive info in text like that see below for emailDoggyDogDog wrote: Tue Jan 13, 2026 3:16 pm Good day, I was wondering if my BD Drive (BDR-XD05s) is flashable for UHD and what needs to be done:
Thank you.Code: Select all
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: ----------- Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 19 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Hello! I also would like to flash my (fairly old) Pioneer BDR-XD05 (S) drive to read UHD discs. Please let me know next steps. Thanks much in advance.
Regards,
pct
OS device name: E:
Revision: 3.00
Serial number:
Firmware date: 2014-07-30
Highest AACS version: 82
Firmware version: 3.00/ID34
Regards,
pct
OS device name: E:
Revision: 3.00
Serial number:
Sure just email me that drive info section see below for emailptripod wrote: Thu Jan 15, 2026 2:58 pm Hello! I also would like to flash my (fairly old) Pioneer BDR-XD05 (S) drive to read UHD discs. Please let me know next steps. Thanks much in advance.
Regards,
pct
OS device name: E:
Revision: 3.00
Serial number:
Hi everyone,
I am new to this forum. I have BDR-XD05TB drive, manufactured June 2018 and was wondering if this drive is flashabe for UHD. Would greatly appreciate any help.
Revision: 3.10
Serial number:
Many thanks
Revision: 3.10
Serial number:
Many thanks
PM sent.chrisg3 wrote: Wed Feb 04, 2026 10:27 pm Hi everyone,
Revision: 3.10
Serial number:
Many thanks
Many thanks. Drive flashed and works like a charm
I'm new to this forum and have a Pioneer BDR-XD05B drive, manufactured in August 2016. I was wondering if this drive is flashable for UHD? If it is, after the PM is sent, what do I do? Do I use the SDFTool Flasher? But then what file from "The All You Need Firmware" do I choose? Any help would be great!
OS device name: E:
Current profile: DVD-ROM
Revision: 3.10
Serial number:
OS device name: E:
Revision: 3.10
Serial number:
Yes email me that drive info section see below for emaillitlucky wrote: Wed Feb 11, 2026 2:23 am Hello,
OS device name: E:
Revision: 3.10
Serial number: PHDL037861UC
