Chuck: Season 2
gabeen
Chuck: Season 2
Post by gabeen »
Chuck: Season 2 have all the episodes merged together into 1 episode in MakeMKV.
MakeMKV maps all the episodes together in the Segment map. All the episodes are seperate files on the actual blu-ray disc.
I have backed up the discs and removed the *.m2ts files and uploaded it here:
https://drive.google.com/open?id=0BypG0 ... XgxeHN6YW8
CHUCK_SEASON_2_DISC_1
Name: Chuck Season 2 Disc 1 (English)
Source file name: 00001.mpls
Duration: 4:19:54
Chapters count: 43
Segment count: 6
Segment map: 6,16,7,18,8,20
File name: Chuck_Season_2_Disc_1_t00.mkv
CHUCK_SEASON_2_DISC_2
Name: Chuck Season 2 Disc 2 (English)
Duration: 4:16:55
Chapters count: 44
Segment count: 6
Segment map: 16,7,8,18,1,6
File name: Chuck_Season_2_Disc_2_t00.mkv
CHUCK_SEASON_2_DISC_3
Name: Chuck Season 2 Disc 3 (English)
Duration: 4:18:07
Chapters count: 43
Segment count: 6
Segment map: 14,6,16,7,18,1
File name: Chuck_Season_2_Disc_3_t00.mkv
CHUCK_SEASON_2_DISC_4
Name: Chuck Season 2 (English)
Duration: 2:52:11
Chapters count: 32
Segment count: 4
File name: Chuck_Season_2_t01.mkv
gabeen
Re: Chuck: Season 2
Post by gabeen »
Update: Just tried the new build, MakeMKV v1.10.2 (11.9.2016 ) - and the issue still occurs.
Could you fix this please? You fixed it for Weeds Season 1.
altano
Re: Chuck: Season 2
Post by altano »
The issue still occurs in 1.10.4 but you can split the track up yourself fairly easily.
Using MKVToolnix, drag&drop the large file from disc 1. You can leave all the settings alone but we need to setup the output to be split: go to Output tab -> "Splitting" Section -> "Split Mode" = "Before Chapters" -> Chapter #s
Set the chapter numbers for disc 1 to "8,15,22,29,36". I had to do a little trial and error to get this right, not sure why the first chapter is off-by-one. Then at the bottom you can click the button to start the job. The chapter markers for all the chapters are:
Disc 1: 8,15,22,29,36
Disc 2: 9,17,24,31,38
Disc 3: 8,15,22,30,37
Disc 4: 9,17,25
Good luck.
cantonhero
Re: Chuck: Season 2
Post by cantonhero »
altano wrote:The issue still occurs in 1.10.4 but you can split the track up yourself fairly easily.
Disc 4: 9,17,25
Good luck.
@altano - You are my hero. Thanks so much for posting this!
The prodigy
Re: Chuck: Season 2
Post by The prodigy »
Came her to second, Altano, you are the man, woman, or person! Thank you!
bt004
Re: Chuck: Season 2
Post by bt004 »
Thank you Altano!
