Is my LG BH16NS40 toast?
flash67
Post by flash67 »
I all of a sudden cannot seem to write onto any BD-R - write errors.
DVDRs work fine.
Is my drive toast? I've had it since I purchased it in December of 2015 for $100CAD.
FW 1.03
zittrig
Re: Is my LG BH16NS40 toast?
Post by zittrig »
Reading BD works? Other BD-R brand tested?
You can try to clean the laser lenses with alcohol and q-tips. Do it twice and dry immediately, not let it dry by air.
If that don't work you can assume that the blue laser is defective.
flash67
Post by flash67 »
zittrig wrote: Mon Dec 29, 2025 12:14 pm Reading BD works? Other BD-R brand tested?
Reading BD works - just threw in a bluray and I can see the folder/files. Don't have any other brands, just have Verbatim BD-R and BD-R DL
flash67
Post by flash67 »
So I just attempted to make an iso of a bluray, which worked fine.
I went to write that same .iso to a bluray and it failed... Would cleaning the lenses work you think?
zittrig
Post by zittrig »
I doubt it. But better check it out instead throwing it in the tin unchecked.
Has power connection changed?
