No. Just install MakeMKV in the default location then remove it once done.argonassassin wrote: Tue Dec 30, 2025 9:09 pm I just downloaded the flasher and have a question about redirecting where it looks for make mkv. Currently on my pc I've stopped downloading things into my C drive unless it's absolutely necessary so when I finished installing the SDF tool flasher it tells me to install Make MKV. Is there any way to change it's hunting path or do I just need to install make mkv onto my C Drive?
Currently make mkv 1.18.2 is installed in D:\Programs\Makemkv.
I don't know if this would work but you might even be able to just copy the MakeMKV directory to "C:\Program Files (x86)" then delete it when you are finished.
