Pioneer BDR-209M
phantom0308
Pioneer BDR-209M
#1 Post by phantom0308 » Mon Dec 29, 2025 3:36 pm
Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.53
Serial number: *
Firmware date: 2019-03-07
Highest AACS version: 82
Firmware version: ID04
Re: Pioneer BDR-209M
#2 Post by Coopervid » Mon Dec 29, 2025 3:42 pm
Revision: 1.53
Serial number: *
PM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.
phantom0308
#3 Post by phantom0308 » Mon Dec 29, 2025 3:54 pm
Revision: 1.53
Serial number: *
OK, thank you
phantom0308
#4 Post by phantom0308 » Mon Dec 29, 2025 4:11 pm
Revision: 1.53
Serial number: *
The problem is solve, the optical drive now could read UHD, thank you!
phantom0308
#5 Post by phantom0308 » Tue Dec 30, 2025 10:39 am
Revision: 1.53
Serial number: *
Hello, I buy another optical drive today, could this be flash to UHD? thank you!
Product: BD-RW BDR-XD08
Revision: 1.01
Serial number: CADL000157CN
Firmware date: 2022-10-11
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
#6 Post by Coopervid » Tue Dec 30, 2025 10:42 am
Revision: 1.53
Serial number: *
Revision: 1.01
Yes. Post again when you have it.
phantom0308
#7 Post by phantom0308 » Tue Dec 30, 2025 10:47 am
Revision: 1.01
OK, thank you, i have already buy it, need i send some pictures to show the optical drive near by me?
#8 Post by Coopervid » Tue Dec 30, 2025 10:53 am
So you have already? I understood it is still on its way to your home. PM is coming for it.
phantom0308
#9 Post by phantom0308 » Tue Dec 30, 2025 3:42 pm
Yes, the delivery service here is quite fast. The seller sent it out in the morning and I received it in the evening. The firmware has been installed and the UHD is now readable. Thank you.
phantom0308
#10 Post by phantom0308 » Thu Jan 01, 2026 4:28 am
Hi, I bought another optical drive, could you send me a firmware to flash? Thanks.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
