Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.53
Serial number: *
Firmware date: 2019-03-07
Highest AACS version: 82
Firmware version: ID04
Pioneer BDR-209M
Re: Pioneer BDR-209M
PM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.phantom0308 wrote: Mon Dec 29, 2025 3:36 pm Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Revision: 1.53
Serial number: *
phantom0308
OK, thank youCoopervid wrote: Mon Dec 29, 2025 3:42 pmPM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.phantom0308 wrote: Mon Dec 29, 2025 3:36 pm Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Revision: 1.53
Serial number: *
phantom0308
The problem is solve, the optical drive now could read UHD, thank you!Coopervid wrote: Mon Dec 29, 2025 3:42 pmPM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.phantom0308 wrote: Mon Dec 29, 2025 3:36 pm Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Revision: 1.53
Serial number: *
phantom0308
Hello, I buy another optical drive today, could this be flash to UHD? thank you!Coopervid wrote: Mon Dec 29, 2025 3:42 pmPM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.phantom0308 wrote: Mon Dec 29, 2025 3:36 pm Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Revision: 1.53
Serial number: *
Product: BD-RW BDR-XD08
Revision: 1.01
Serial number: CADL000157CN
Firmware date: 2022-10-11
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
Yes. Post again when you have it.phantom0308 wrote: Tue Dec 30, 2025 10:39 amHello, I buy another optical drive today, could this be flash to UHD? thank you!Coopervid wrote: Mon Dec 29, 2025 3:42 pmPM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.phantom0308 wrote: Mon Dec 29, 2025 3:36 pm Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Revision: 1.53
Serial number: *
Revision: 1.01
phantom0308
OK, thank you, i have already buy it, need i send some pictures to show the optical drive near by me?Coopervid wrote: Tue Dec 30, 2025 10:42 amYes. Post again when you have it.phantom0308 wrote: Tue Dec 30, 2025 10:39 amHello, I buy another optical drive today, could this be flash to UHD? thank you!Coopervid wrote: Mon Dec 29, 2025 3:42 pm
Revision: 1.01
So you have already? I understood it is still on its way to your home. PM is coming for it.
phantom0308
Yes, the delivery service here is quite fast. The seller sent it out in the morning and I received it in the evening. The firmware has been installed and the UHD is now readable. Thank you.Coopervid wrote: Tue Dec 30, 2025 10:53 am So you have already? I understood it is still on its way to your home. PM is coming for it.
phantom0308
Hi, I bought another optical drive, could you send me a firmware to flash? Thanks.Coopervid wrote: Tue Dec 30, 2025 10:53 am So you have already? I understood it is still on its way to your home. PM is coming for it.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
