No Country For Old Men
Scrondar
#1 Post by Scrondar » Wed Mar 07, 2012 10:22 pm
Hi- My first post, so please be kind :D
Tried ripping this BD title last night with the program (latest version) and it failed immediately. I'm not in front of my computer right now, so I can't provide an error code, but I wonder if anyone has succeeded with this disc. I'll try again tonight and post any other info that might be useful. Please reply if you've managed to get this title converted. Thanks!
setarip_old
Re: No Country For Old Men
#2 Post by setarip_old » Wed Mar 07, 2012 11:20 pm
Hi!
Absolutely no problem ripping this semi-ancient Blu-ray to either a "Full Disc" Blu-ray or "Movie only" .MKV...
Scrondar
#3 Post by Scrondar » Thu Mar 08, 2012 3:20 am
Attached is the fail screen I get when the program begins to access the disc:
Any idea what's going on here? I also tried ripping this disc to .MKV with DVDfab, and it failed as well. :?:
celavey
#4 Post by celavey » Thu Mar 08, 2012 6:55 am
You may also try to create a virtual disc from the physical disc you have and then create MKV right after from that virtual disc.
Scrondar
#5 Post by Scrondar » Thu Mar 08, 2012 7:07 pm
OK, I'll give that a try, thanks.. Just wondering if this disc has encryption or copy protection that prevents it from being ripped to MKV? I was able to rip it to an AVI file, which looks great, but I'd still like to get MakeMKV to work.
setarip_old
#6 Post by setarip_old » Fri Mar 09, 2012 5:48 am
I guess you didn't read my first post to this thread very carefully...
Scrondar
#7 Post by Scrondar » Fri Mar 09, 2012 3:48 pm
I guess I did. Too bad there was no useful information in it. :roll:
Don't bother responding if you have nothing to contribute. First rule of forum etiquette.
setarip_old
#8 Post by setarip_old » Fri Mar 09, 2012 8:37 pm
When I posted:
it means NO to your subsequent post where you state/ask:
efithian
#9 Post by efithian » Wed Jul 18, 2012 4:34 pm
This has LPCM lossless audio, which makes the disc impossible to copy. Uncheck that option and it works.
BlackDragon24
#10 Post by BlackDragon24 » Wed Jul 18, 2012 5:20 pm
efithian wrote:This has LPCM lossless audio, which makes the disc impossible to copy. Uncheck that option and it works.
I've copied many a disc with LPCM lossless audio.
IrishPrince
#11 Post by IrishPrince » Fri Jul 20, 2012 1:11 am
That did the trick! I have copied quite a few Blu-ray discs with LPCM but this was the first that caused the disc to fail to copy. I bought the disc a week ago at BestBuy... I'm wondering if a new pressing did something to cause MakeMKV to have a problem with this disc?
Anyhoo, thanks for the tip!
-IP
Boxcab
#12 Post by Boxcab » Tue Jun 09, 2026 3:23 pm
Just had the same problem ripping this BR.
Omitting the LPCM track corrected the issue. Seems like an interesting issue for the developers.
