Krondorf
Post by Krondorf » Mon Dec 15, 2025 8:07 am
Actually... i'm pretty sure it can't...
Drive was manufactured 2014 :(
rubenegmond
Post by rubenegmond » Mon Dec 29, 2025 7:22 pm
Hello I tried flashing my ASUS BW-16D1H-U E116 today but to no avail, I managed to get the Updating Failure #1 is the bin file provided in the firmware pack old? Could anyone help me please.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: CCDL090057WL
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
Post by MartyMcNuts » Tue Dec 30, 2025 3:11 am
rubenegmond wrote: Mon Dec 29, 2025 7:22 pm Hello I tried flashing my ASUS BW-16D1H-U E116 today but to no avail, I managed to get the Updating Failure #1 is the bin file provided in the firmware pack old? Could anyone help me please.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
This is a Pioneer drive. You cannot flash this with the public tools. Contact Billycar11 and he should be able to help you.
Krondorf
Post by Krondorf » Sun Feb 01, 2026 5:16 am
Howdy, having to upgrade the drive in my HP SFF PC and i'm thinking of getting this:
https://www.amazon.com.au/dp/B09XTBXM67
Thoughts? Would this be flashable etc?
Post by Billycar11 » Sun Feb 01, 2026 5:36 am
Krondorf wrote: Sun Feb 01, 2026 5:16 am Howdy, having to upgrade the drive in my HP SFF PC and i'm thinking of getting this:
bu50n is just a HP rebrand of BU40N so should be flashable
yackov_bd
Post by yackov_bd » Sun Feb 08, 2026 9:48 am
Hello all!, I just got an Asus Drive, BW-16D1H-U, and without any flashing it let me rip 4k blurays, the question that I have is... Should I flash it anyway or not?. The info on the drive is the following:
Información de unidad de disco
Nombre del SO del dispositivo: /dev/sr0
Fabricante: ASUS
Producto: BW-16D1H-U
Revisión: A201
Número de serie: SIK9TH77E364
Fecha del firmware: 2116-01-14 13:58
Marcas de cifrado bus: 1F
Highest AACS version: 77
Firmware version: 0.A201W
No hay disco insertado
I appreciate your opinions and advice, thank you!
Post by Billycar11 » Sun Feb 08, 2026 11:14 am
yackov_bd wrote: Sun Feb 08, 2026 9:48 am Hello all!, I just got an Asus Drive, BW-16D1H-U, and without any flashing it let me rip 4k blurays, the question that I have is... Should I flash it anyway or not?. The info on the drive is the following:
Fabricante: ASUS
Revisión: A201
yes that can beflashed to do UHD see guide below or email me or marty for an auto flasher
Krondorf
Post by Krondorf » Wed Feb 11, 2026 5:05 am
Billycar11 wrote: Sun Feb 01, 2026 5:36 am
Just got the drive, and installed it...
I can't read bluray discs at all... unless i start makemkv first... is that normal? Haven't tried any other software yet...
I would have though it would let me read a disc at least?
Edit: my external buffalo drive from earlier seems to be able to read discs without makemkv running...
New drive info:
OS device name: F:
Current profile: DVD-ROM
Product: BD-RE BU50N
Revision: CC01
Serial number: 708HS009586
Firmware date: 2117-06-28 09:34
Bus encryption flags: 1F
Highest AACS version: 28
Firmware version: 0.CC01V
Post by Billycar11 » Wed Feb 11, 2026 5:21 am
Krondorf wrote: Wed Feb 11, 2026 5:05 am Just got the drive, and installed it...
not normal you should see the disc in the os before ever opening makemkv
Krondorf
Post by Krondorf » Wed Feb 11, 2026 5:26 am
That's what i thought too...
but i can reproduce it...
load makemkv i can read disc...
close makemkv and insert disc.. nothing...
Edit:
Actually.. weird thing.... i left it sitting while sending message to seller... and after about 5 minutes the disc info popped up in explorer... weird...
will have to investigate
