Pioneer BDR-209M
phantom0308
Pioneer BDR-209M
Post by phantom0308 »
Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.53
Serial number: *
Firmware date: 2019-03-07
Highest AACS version: 82
Firmware version: ID04
Re: Pioneer BDR-209M
phantom0308 wrote: Mon Dec 29, 2025 3:36 pm Hello, I recently purchased this optical drive. I would like to ask if it is possible to flash the firmware of this optical drive to support UHD? Thanks!
Revision: 1.53
Serial number: *
PM is coming. Don't be confused. This is a camouflaged 212 drive even it says 209 in the product info.
phantom0308
Coopervid wrote: Mon Dec 29, 2025 3:42 pm
Revision: 1.53
Serial number: *
OK, thank you
phantom0308
Revision: 1.53
Serial number: *
The problem is solve, the optical drive now could read UHD, thank you!
phantom0308
Revision: 1.53
Serial number: *
Hello, I buy another optical drive today, could this be flash to UHD? thank you!
Product: BD-RW BDR-XD08
Revision: 1.01
Serial number: CADL000157CN
Firmware date: 2022-10-11
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
phantom0308 wrote: Tue Dec 30, 2025 10:39 am
Revision: 1.53
Serial number: *
Revision: 1.01
Yes. Post again when you have it.
phantom0308
Coopervid wrote: Tue Dec 30, 2025 10:42 am
Revision: 1.01
OK, thank you, i have already buy it, need i send some pictures to show the optical drive near by me?
So you have already? I understood it is still on its way to your home. PM is coming for it.
phantom0308
Coopervid wrote: Tue Dec 30, 2025 10:53 am So you have already? I understood it is still on its way to your home. PM is coming for it.
Yes, the delivery service here is quite fast. The seller sent it out in the morning and I received it in the evening. The firmware has been installed and the UHD is now readable. Thank you.
phantom0308
Hi, I bought another optical drive, could you send me a firmware to flash? Thanks.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
