PM sent.franklinkayq wrote: ↑Thu Dec 25, 2025 7:56 amDrive Information
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: RADL136086UC
Firmware date: 2017-06-22
Highest AACS version: 68
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Is my pioneer BDR-XD05s flashable?
Re: Is my pioneer BDR-XD05s flashable?
also looking to patch a BDR-XD05, thanks for any help
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 82
Drive platform: RS8231
Firmware version: 3.01/ID34
Revision: 3.01
Serial number:
I also need some help flashing mine to make it 4K worthy, and thank you for your time in advance.
heres my drive information if anyone could help me get it to detect 4k. Thanks in advance.
OS device name: F:
Revision: 3.10
Serial number: QFDL114993UC
Highest AACS version: 58
OS device name: F:
Revision: 3.10
PM sent.NathanW wrote: ↑Sat Dec 27, 2025 2:54 amheres my drive information if anyone could help me get it to detect 4k. Thanks in advance.
OS device name: F:
Revision: 3.10
Am I out of luck then?churrs wrote: ↑Fri Dec 26, 2025 10:30 pmalso looking to patch a BDR-XD05, thanks for any help
Revision: 3.01
Serial number:
PM sent.churrs wrote: ↑Sat Dec 27, 2025 4:53 pmAm I out of luck then?churrs wrote: ↑Fri Dec 26, 2025 10:30 pmalso looking to patch a BDR-XD05, thanks for any help
Revision: 3.01
Serial number:
Unrestricted read speed: Yes![]()
Hello @Coopervid, appreciation your help on this. Can you confirm if there are any updates for this drive? Thanks
Current profile: DVD-ROM
Revision: 3.10
Serial number:
Highest AACS version: 14
Revision: 3.10
Serial number:
PM sent.DJ Dannis wrote: ↑Sat Dec 27, 2025 11:31 pmHello @Coopervid, appreciation your help on this. Can you confirm if there are any updates for this drive? Thanks
Revision: 3.10
Serial number:
westernblink
Would this drive be flashable to support UHD? Thanks in advance for any help.
OS device name: G:
Revision: 3.01
Serial number:
OS device name: G:
Revision: 3.01
Serial number:
JohnnyBGoode
Can this drive be flashed? Uhd capable?
OS device name: E:
Revision: 3.01
Serial number:
Highest AACS version: 12
BD raw metadata read: Yes Unrestricted read speed: Yes
OS device name: E:
Revision: 3.01
Serial number:
PM sent.westernblink wrote: ↑Sun Dec 28, 2025 11:12 amWould this drive be flashable to support UHD? Thanks in advance for any help.
OS device name: G:
Revision: 3.01
Serial number:
PM is coming.JohnnyBGoode wrote: ↑Sun Dec 28, 2025 6:11 pmCan this drive be flashed? Uhd capable?
OS device name: E:
Revision: 3.01
Serial number:
DigitalJockey
I was wondering if mine is flashable as well.
OS device name: H:
Revision: 3.10
Serial number: OEDL058605UC
Thank you.
OS device name: H:
Revision: 3.10
Thank you.
PM sent.DigitalJockey wrote: ↑Sun Dec 28, 2025 8:22 pmHello,
OS device name: H:
Revision: 3.10
Thank you.
