Thanks a million - that worked flawlessly. Putting it to the test now with LOTR FOTR Extended versionCoopervid wrote: Thu Dec 25, 2025 11:38 amPM sent.mrhrphillips wrote: Wed Dec 24, 2025 7:28 am Looking for some guidance on whether this drive is flashable:
OS device name: K:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: xxxxxxxxxxxx
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
Thanks,
Harold
ASUS BW-16D1X-U - Flashable?
mrhrphillips
Re: ASUS BW-16D1X-U - Flashable?
Yours is a LG drive. You should be able to flash it directly to WH16NS60 1.02-MK and you are good to go.qitsnm wrote: Thu Dec 25, 2025 10:06 pm I am looking for the firmware but I see that my Revision number is different than the others in this thread.
Can anybody point me to the correct firmware?
OS device name: G:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 68
Hi there Coopervid I didn't want to get missed in that slew of requests. Is this drive possible?upb123 wrote: Thu Dec 25, 2025 5:06 am Hi there, I also have the same drive. Might I trouble ya for the firmware as well?
Please and thank you![]()
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware version: ID76
Hi! A few months ago, I successfully flashed my ASUS BW-16D1X-U using HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin from "The all you need firmware pack". All was well. I could read all kinds of discs -- until today, when the drive suddenly stopped reading any kind of disc. This is not an issue of a given dirty or damaged disc. Nothing -- not even CDs -- is recognized. I can insert a disc manually, and I can open the drive tray using the eject button in MakeMKV, but nothing is recognized, and I just see "No disc inserted".
Before assuming the drive is dead (though it may be?), I thought I would try re-flashing the firmware. So I downloaded the relevant files again, and followed the "Mac/linux commands to flash" (I have a Mac) in the "Ultimate UHD Drives Flashing Guide Updated 2025". The output from the process concluded with "Done successfully". However, the drive still doesn't recognize any inserted disc of any kind.
Here's the info from MakeMKV:
Any ideas? Anything else I can check? I should note that I've done this with all other peripherals (other than my monitor and the ASUS BW-16D1X-U itself) disconnected, with the physical ASUS BW-16D1X-U drive plugged directly into the computer (no hubs or anything).
If the drive has to be declared dead [sigh
] then what's the currently best recommended replacement that would allow ripping 4k/UHD discs?
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLIM8IJ2503
Firmware version: 1.02
No disc insertedIf the drive has to be declared dead [sigh
Most likely dead.
So I have feared.
Well, Amazon US lists a "Produplicator LG BP60NB10", which I am guessing is (or is the equivalent of, or contains) the "BP60NB10 NB10/12" listed in the "Recommended UHD Drives to get" section of the "Ultimate UHD Drives Flashing Guide Updated 2025". Is my guess likely to be correct? I might have to get myself a late Xmas present.
Post the link.carlsefni wrote: Fri Dec 26, 2025 7:31 pmSo I have feared.![]()
Well, Amazon US lists a "Produplicator LG BP60NB10", which I am guessing is (or is the equivalent of, or contains) the "BP60NB10 NB10/12" listed in the "Recommended UHD Drives to get" section of the "Ultimate UHD Drives Flashing Guide Updated 2025". Is my guess likely to be correct? I might have to get myself a late Xmas present.![]()
https://a.co/d/3B4oVNH
There seem relatively limited options for recommended plug'n'play external drives. (I'd prefer to not mess about with putting an internal drive in an external enclosure, if possible!) I suppose I can try to find one of the other LG options on eBay, if not Amazon.
You can go for it.carlsefni wrote: Fri Dec 26, 2025 8:14 pmhttps://a.co/d/3B4oVNH
Great, thanks. I'll give it a go. At least I am reasonably familiar with the flashing process at this point!
carlsefni wrote: Fri Dec 26, 2025 5:36 pm Hi! A few months ago, I successfully flashed my ASUS BW-16D1X-U using HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin from "The all you need firmware pack". All was well. I could read all kinds of discs -- until today, when the drive suddenly stopped reading any kind of disc. This is not an issue of a given dirty or damaged disc. Nothing -- not even CDs -- is recognized. I can insert a disc manually, and I can open the drive tray using the eject button in MakeMKV, but nothing is recognized, and I just see "No disc inserted".
Here's the info from MakeMKV:Any ideas? Anything else I can check? I should note that I've done this with all other peripherals (other than my monitor and the ASUS BW-16D1X-U itself) disconnected, with the physical ASUS BW-16D1X-U drive plugged directly into the computer (no hubs or anything).Code: Select all
Drive Information Manufacturer: HL-DT-ST Product: BD-RE WH16NS60 Revision: 1.02 Serial number: KLIM8IJ2503 Firmware date: 2118-10-29 19:36 Bus encryption flags: 17 Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
If the drive has to be declared dead [sigh] then what's the currently best recommended replacement that would allow ripping 4k/UHD discs?
Power off the drive and computer completely for a few minutes then reboot both. Sometimes drives can get in a confused state and won’t recognise any discs.
I successfully flashed the drive with DE_LG_WH16NS60_1.02_MK.bin and was able to rip several region 2 discs. I resumed the process a few hours later (a 9 season TV Series) and had only failures. I tried again today and now MakeMKV doesn't recognize the drive. I re-flashed with DE_LG_WH16NS60_1.02_MK but it's still not recognized. I can open, view, and select files with Windows 11 File Explorer, so i'm guessing that the drive is functional. Any suggestions?MartyMcNuts wrote: Fri Dec 26, 2025 6:53 amYours is a LG drive. You should be able to flash it directly to WH16NS60 1.02-MK and you are good to go.qitsnm wrote: Thu Dec 25, 2025 10:06 pm I am looking for the firmware but I see that my Revision number is different than the others in this thread.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Don't reflash it. That's not the issue. LG drives sometimes get themselves into a confused state. Power off the drive completely for 10 minutes then restart it. Sometimes the PC may need to be shutdown completely too.qitsnm wrote: Sat Dec 27, 2025 7:58 pmI successfully flashed the drive with DE_LG_WH16NS60_1.02_MK.bin and was able to rip several region 2 discs. I resumed the process a few hours later (a 9 season TV Series) and had only failures. I tried again today and now MakeMKV doesn't recognize the drive. I re-flashed with DE_LG_WH16NS60_1.02_MK but it's still not recognized. I can open, view, and select files with Windows 11 File Explorer, so i'm guessing that the drive is functional. Any suggestions?MartyMcNuts wrote: Fri Dec 26, 2025 6:53 amYours is a LG drive. You should be able to flash it directly to WH16NS60 1.02-MK and you are good to go.qitsnm wrote: Thu Dec 25, 2025 10:06 pm I am looking for the firmware but I see that my Revision number is different than the others in this thread.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
I see others list this drive, but I am missing the line "Highest AACS version." Is this drive flashable? If it makes a difference, I use the drive on an Ubuntu system, and only have it on Windows to flash it. I have SPFtool flasher and All you need firmware pack
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Yep, flash to WH16NS60 1.02-MK and you are good to go.kscrib wrote: Sun Dec 28, 2025 7:05 pm I see others list this drive, but I am missing the line "Highest AACS version." Is this drive flashable? If it makes a difference, I use the drive on an Ubuntu system, and only have it on Windows to flash it. I have SPFtool flasher and All you need firmware pack
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
