This Is Spinal Tap Criterion Bluray disc 1 wonr rip
PerVers
#1 Post by PerVers » Mon Dec 15, 2025 6:38 pm
hey so i have ripped the bluray disc 2 and the 4k disc with no probelms but the first blury disc just wont work
i have tried for 2 months now
can somone put a step by step dummy guide for me
thank you
MakeMKV v1.18.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Max/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=A05DF1FAE171)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?dRkHmgO98bLJpW...
DEBUG: Code 0 at 3}LEXDFfdV,&S#:f:121268443
Saved AACS dump file as C:\Users\Max/.MakeMKV/MKB_v82_THIS_IS_SPINAL_TAP_-_DISC_ONE_DACE.tgz
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213131341
Näyttökuva (380).png (157.78 KiB) Viewed 22754 times
Re: This Is Spinal Tap Criterion Bluray disc 1 wonr rip
#2 Post by dcoke22 » Wed Dec 17, 2025 9:51 pm
Regular blu-rays that use the latest version of encryption, AACS v82, have to handled slightly differently than regular blu-rays with older versions of encryption.
MakeMKV supports two different disc decryption mechanisms. The built-in mechanism is called hashed keys and it works with all dumps from MakeMKV regardless of the brand of drive. When there is not a key for your disc and MakeMKV produces a dump, email that dump to svq@makemkv.com. Eventually a hashed key will be produced and MakeMKV will automatically download it as needed.
The other source for decryption keys is the public keyDB. The first post in the Public KeyDB Disc Submissions thread includes a template and instructions on how to submit dumps for inclusion in the keyDB. It also has links to where the keyDB can be downloaded, utilities to help keep it updated, and where to put the file so MakeMKV can use it. Dumps from Pioneer drives can't generally be used for keyDB submissions. However, MakeMKV can use the keys provided by the public keyDB with any brand of optical drive.
These two ways to decrypt discs can be used together. If you can submit a dump to the keyDB you can also email it to svq@makemkv.com. Accidental duplicates emailed to MakeMKV aren't a big deal but duplicates submitted to the keyDB should be avoided if possible.
PerVers
#3 Post by PerVers » Fri Dec 19, 2025 2:32 pm
so what do i need to do i am still new to the keys and stuff so what do i send and to where
thank you in advance
PerVers
#4 Post by PerVers » Fri Dec 19, 2025 2:40 pm
dcoke22 wrote: Wed Dec 17, 2025 9:51 pm Regular blu-rays that use the latest version of encryption, AACS v82, have to handled slightly differently than regular blu-rays with older versions of encryption.
MakeMKV supports two different disc decryption mechanisms. The built-in mechanism is called hashed keys and it works with all dumps from MakeMKV regardless of the brand of drive. When there is not a key for you disc and MakeMKV produces a dump, email that dump to svq@makemkv.com. Eventually a hashed key will be produced and MakeMKV will automatically download it as needed.
so if i understood correctly after i have tried to open it with makemkv i sned to that email adress the rar files of the dump and ask them to this is the disc one of thsi pelase add it to the database or somethign along the lines
#5 Post by dcoke22 » Sun Dec 21, 2025 3:17 pm
Just attach the .tgz file to an email and send it to the address.
PerVers
#6 Post by PerVers » Sat Dec 27, 2025 6:35 pm
thank you. i sent most of dics i had probelems with
where do i get t know that they are working now?
#7 Post by dcoke22 » Sat Dec 27, 2025 10:20 pm
Since it has been a few days, try to rip the disc again. If new keys have been released MakeMKV will try to download them when it needs to. There should be a message in the log about downloading the latest HK.
PerVers
#8 Post by PerVers » Thu Feb 19, 2026 12:49 am
still dosent work
