Post your Makemkv info.khobar95 wrote: Fri Dec 26, 2025 3:57 am I would very much like the same. BDR-212V, but no disc when trying to read a UHD.
What else, if anything, do I need to post to get the guide?
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
PM sent.Cooly1911 wrote: Fri Dec 26, 2025 1:46 am I'm new to this, can I flash this unit? I would appreciate some instructions. I tried the SDF tool and it had a big red X.
Thank you!
OS device name: /dev/sr1
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.01
Serial number:
Firmware date: 2021-07-20
Bus encryption flags: 13
Firmware version: ID06
Thanks very much!
My info:
OS device name: F:
Revision: 1.00
Serial number: ADDL010074WL
Firmware date: 2020-08-07
Highest AACS version: 72
Drive platform: RS8F00
Firmware version: 1.00/ID06
My info:
OS device name: F:
Revision: 1.00
PM sent.khobar95 wrote: Fri Dec 26, 2025 4:50 pm Thanks very much!
My info:
OS device name: F:
Revision: 1.00
I worked! Thank You!!Coopervid wrote: Fri Dec 26, 2025 10:02 amPM sent.Cooly1911 wrote: Fri Dec 26, 2025 1:46 am I'm new to this, can I flash this unit? I would appreciate some instructions. I tried the SDF tool and it had a big red X.
Thank you!
Revision: 1.01
Serial number:
Aardyark37
I just got this drive, and I'm looking for help with flashing it. Information is as follows:
Product: BD-RW BDR-212D
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Highest AACS version: 81
Firmware version: 1.00/ID61
Edit: Coopervid is the goat. Thank you so much!
Revision: 1.00
Serial number:
PM sent.Aardyark37 wrote: Tue Dec 30, 2025 1:59 am I just got this drive, and I'm looking for help with flashing it. Information is as follows:
Revision: 1.00
Serial number:
Provable9375
Hello, I'd also like info on flashing my drive for UHD ripping
OS device name: H:
Revision: 1.00
Serial number:
Highest AACS version: 68
No disc insertedRe: BDR 212V UHD Guide
PM sent.Provable9375 wrote: Tue Dec 30, 2025 10:06 pm Hello, I'd also like info on flashing my drive for UHD ripping
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.00 Serial number: Firmware date: 2019-01-10 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.00/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
bolusofdoom
Yet another person looking for info on flashing my BDR-212V drive for UHD ripping. Thank you.
Revision: 1.02
Serial number: TJDL000044WL
Firmware date: 2022-05-31
Highest AACS version: 70
PM sent.bolusofdoom wrote: Fri Jan 02, 2026 9:39 am Yet another person looking for info on flashing my BDR-212V drive for UHD ripping. Thank you.
Revision: 1.02
bolusofdoom
It worked, thank you!
TunaClownfish
Hoping to get information on if this drive can be UHD enabled? Thank you!
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 82
Firmware version: E113/ID76
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
yeah it can do UHD email me that info for the flasher see belowTunaClownfish wrote: Mon Jan 12, 2026 11:16 pm Hi,
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Hello, I am new on here. I have a drive BW-16D1H-U PRO that cannot read UHD. Can you help me.
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware version: E116/ID71
Thanks,
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Thanks,
