jackcholt
Post by jackcholt »
After reading the instructions in the OP still unsure what bin file to use. I'm on linux and MakeMKV says:
OS device name: /dev/sr0
Current profile: CD-ROM
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO1P5695201
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: MANUALS_AND_APP
Timestamp: 1899-12-30
Data capacity: 0.21 Gb
Which firmware should I use?
jackcholt wrote: Wed Dec 24, 2025 4:29 am After reading the instructions in the OP still unsure what bin file to use. I'm on linux and MakeMKV says:
Revision: 1.02
Disc Information
BU40N 1.03-MK
quirkyspectacular
Post by quirkyspectacular »
Haven't ripped in a few months and obviously my drive is no longer working.
Here's my Drive Info:
OS device name: /dev/rdisk4
Revision: 1.03
Serial number:
Firmware version: 1.03
Username:0000
Post by Username:0000 »
Hi All,
Please can someone help me with flashing my Verbatim Blu-Ray drive?
Details from MakeMKV
OS device name: F:
Revision: 1.05
Serial number: MOEP7I95102
Will LibreDrive be compatible with AnyDVD?
As I still have that installed on my system, despite the software now been defunct.
I might move onto using xreveal https://www.xreveal.com/in the future as its very similar to AnyDVD.
Username:0000 wrote: Wed Dec 24, 2025 2:16 pm Hi All,
OS device name: F:
Revision: 1.05
viewtopic.php?f=16&t=22896&hilit=sdfTool
Yes, it will be compatible with AnyDVD and XReveal. For both programs you should use the KEYDB.cgf.
quirkyspectacular
quirkyspectacular wrote: Wed Dec 24, 2025 12:54 pm Haven't ripped in a few months and obviously my drive is no longer working.
Revision: 1.03
Serial number:
I was able to update using the SDF tool. I'm still getting errors though and not sure how to fix.
Revision: 1.03
Serial number: MO1OAME2043
Disc Information
Label: SINNERS
Timestamp: 2025-06-04 08:38:31
Protection: AACS2.0/C v82
Data capacity: 84.5 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Here's log:
DEBUG: Code 0 at Sc?u1WE?GY![mcZUU:121261405
DEBUG: Code 0 at 0O%e>jY}|Ee5'jF##:29394873
DEBUG: Code 0 at iwR'HM::<wMf\TLm:213136585
Error 'Posix error - Operation not permitted' occurred while creating '/Volumes/MKB20_v82_Sinners_6E90.tgz'
DEBUG: Code 0 at b:?~!"NmQOllf7=&:213132721
DEBUG: Code 0 at b:?~!"NmQOllf7=&:213131341
dynasty8122
is the list of drives in the original post actually updated for 2025?
Post by dynasty8122 »
The posting date on that original post is 2019. I've checked a few of the recommended drives & didn't find any that were available for sale new (which, I get it--the physical media industry is kind of on the downswing). So maybe I do really need to e.g., scour ebay for the oldies. But seeing that there are 200 pages on this thread+ makes me afraid that the actually-updated list is somewhere else in the forum-thread-haystack if you know what I mean... Thanks in advance!
You should read this:
viewtopic.php?f=12&t=38293
quirkyspectacular wrote: Wed Dec 24, 2025 6:10 pm
Revision: 1.03
Serial number:
Revision: 1.03
Disc Information
Label: SINNERS
Number of layers: 3
Here's log:
did you change the makemkv data directory ?
makemkv is reporting it cant write at all
this can be caused by a few things changing the directory to a place you dont have permission to access or a drive that was removed or even trying to write back to the disc it self seen that way to many times
Re: is the list of drives in the original post actually updated for 2025?
dynasty8122 wrote: Wed Dec 24, 2025 8:10 pm The posting date on that original post is 2019. I've checked a few of the recommended drives & didn't find any that were available for sale new (which, I get it--the physical media industry is kind of on the downswing). So maybe I do really need to e.g., scour ebay for the oldies. But seeing that there are 200 pages on this thread+ makes me afraid that the actually-updated list is somewhere else in the forum-thread-haystack if you know what I mean... Thanks in advance!
yes its actually updated why else would i say it is.
the problem is all bluray drives for pc's are pretty much out of production
quirkyspectacular
Billycar11 wrote: Wed Dec 24, 2025 11:09 pm
Revision: 1.03
Serial number:
Revision: 1.03
Disc Information
Label: SINNERS
Number of layers: 3
Here's log:
Possibly! Where does it need to point?
nicholfd
Post by nicholfd »
Did you look in the "For Sale" forum: Drives for sale, Flashing Services, where to buy... ?
Many new (current models that are the only thing available) for sale there. I have 4 x models available for purchase, pre-flashed. Links are in my signature.
Thanks,
Frank
dynasty8122
nicholfd wrote: Thu Dec 25, 2025 3:17 am
::snip::
I did not--but I will now. Thanks!
Username:0000
Coopervid wrote: Wed Dec 24, 2025 2:57 pm
OS device name: F:
Revision: 1.05
Thanks for the reply, where can I get hold of the KEYDB.cgf please?
nicholfd
Post by nicholfd »
Username:0000 wrote: Sat Dec 27, 2025 3:38 pm
OS device name: F:
Revision: 1.05
In these forums. Please try to help yourself.
