Dune - Part Two UHD
BermudaLamb
Dune - Part Two UHD
Post by BermudaLamb »
I'm getting an error trying rip a UHD of Dune: Part Two, this is my drive configuration. I've attached the log for the process.
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: M67ICR43642
Firmware date: 2117-04-25 17:56
Highest AACS version: 77
Firmware version: 1.00
UPDATE ZIP LOG FILE
MakeMKV_log.zip
(21.19 KiB) Downloaded 173 times
Re: Dune - Part Two UHD
Your 22 byte zip file doesn't seem to have anything in it. Perhaps just copy & paste the log into code tags in a post in this thread.
Without knowing what's going on in your particular case I can say for lots of errors, the default advice is to gently clean the disc and try again.
BermudaLamb
Debug log started at Mon Dec 22 14:04:03 2025 , written by MakeMKV v1.18.2 win(x64-release)
001005:0000 MakeMKV v1.18.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\thoml/MakeMKV_log.txt
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
SDF  v0a3: HL-DT-ST_BD-RE__WH16NS60_1.00_211704251756_M67ICR43642
001011:0000 Using LibreDrive mode (v06.3 id=4FBA32AEC678)
DEBUG: Code 2147483648 at 3}LEXDFfdV,&S#:f:121265499
003338:0000 Downloading latest HK to C:\Users\thoml/.MakeMKV ...
Found java version=1.8.0.471 path=C:\Program Files (x86)\Java\jre1.8.0_471\bin\java.exe
Found java version= path=C:\Program Files (x86)\Common Files\Oracle\Java\java8path\java.exe
003344:0000 Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_471\bin\java.exe
DISCID=261D902296E398F21E4DCFB07F13513A04F63C05
003025:0000 Title #00000.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 3221225653 at ]I}b{0 4_E'3uc%{:213130559
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '847872'
DEBUG: Code 3221225653 at _worNE:(,lg'T'0g]I:29394896
001003:0020 DEBUG: Code 3221225653 at _worNE:(,lg'T'0g]I:213131502
001003:0020 DEBUG: Code 3221225653 at _worNE:(,lg'T'0g]I:121263429
001003:0020 DEBUG: Code 3221225653 at _worNE:(,lg'T'0g]I:121262302
001003:0020 DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:29395793
001003:0020 DEBUG: Code 0 at h97u/P'k6LzLo#gYp;Jg:29394068
001003:0020 DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:213131157
001003:0020 DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:121262647
001003:0020 DEBUG: Code 414 at %>PdCTzv+:fz/M&2tT6A:121261773
001003:0020 DEBUG: Code 0 at i/H}:?)1\gS3zNV0E<wE:121269179
001003:0020 DEBUG: Code 0 at 3}>P7*/u^FPKJstTL.F:213132836
001003:0020 DEBUG: Code 0 at `%:o_3i{$p}!{5=$@:121265315
001003:0020 DEBUG: Code 0 at Dg(8o$hlH'Xo6Zuv00:121262049
001003:0020 DEBUG: Code 0 at Dg(8o$hlH'Xo6Zuv00:121262256
005043:0000 Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
001003:0020 DEBUG: Code 0 at qPrqk48j.=EF(L?2:213131387
001003:0020 DEBUG: Code 0 at :t)J\K~s]9NdQWC:213138494
001003:0020 DEBUG: Code 0 at K/7I6&O",`|u5 8d:29381878
003016:0000 Title #00009.mpls was skipped
003025:0000 Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 100864261 at lS]g`,`;]*O'8w*t:121271617
001003:0020 DEBUG: Code 100864261 at ]I}b{0 4_E'3uc%{:213130559
001003:0020 DEBUG: Code 100941314 at lS]g`,`;]*O'8w*t:121271617
001003:0020 DEBUG: Code 100941314 at ]I}b{0 4_E'3uc%{:213130559
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00059.m2ts' at offset '792576'
DEBUG: Code 100941314 at _worNE:(,lg'T'0g]I:29394896
001003:0020 DEBUG: Code 100941314 at _worNE:(,lg'T'0g]I:213131502
001003:0020 DEBUG: Code 100941314 at _worNE:(,lg'T'0g]I:121263429
001003:0020 DEBUG: Code 100941314 at _worNE:(,lg'T'0g]I:121262302
001003:0020 DEBUG: Code 129 at h97u/P'k6LzLo#gYp;Jg:213133687
001003:0020 DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:121262348
001003:0020 DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:121262210
001003:0020 DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:121261773
001003:0020 DEBUG: Code 387 at %>PdCTzv+:fz/M&2tT6A:121261773
003016:0000 Title #00093.mpls was skipped
003025:0000 Title #00153.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00806.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00809.mpls was added as title #1
003307:0000 File 00810.mpls was added as title #2
003307:0000 File 00811.mpls was added as title #3
003307:0000 File 00812.mpls was added as title #4
003307:0000 File 00813.mpls was added as title #5
003307:0000 File 00814.mpls was added as title #6
003307:0000 File 00815.mpls was added as title #7
003307:0000 File 00816.mpls was added as title #8
003025:0000 Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
BermudaLamb
Continued
005043:0000 Failed to decode audio/video data for title #9 - invalid mux or internal error, title skipped.
003016:0000 Title #00008.m2ts was skipped
003025:0000 Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00059.m2ts' at offset '4780032'
001003:0020 DEBUG: Code 2334 at %>PdCTzv+:fz/M&2tT6A:121261773
003016:0000 Title #00059.m2ts was skipped
003025:0000 Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00075.m2ts was added as title #9
002023:0000 Encountered 52 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=3 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
error=0x06043E02 count=49 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
Encountered 70 unclassified errors
error=0xC00000B5 count=70 name=OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired
005014:0000 Saving 1 titles into directory file://G:/Video4k/D/Dune- Part Two (2024)
AV sync issues in G:/Video4k/D/Dune- Part Two (2024)/Dune- Part Two-FPL_MainFeature_t00.mkv
AV sync in 3 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18ms
AV sync in 4 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18ms
AV sync in 5 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18ms
AV sync in 6 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18ms
AV sync in 7 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18ms
AV sync in 3,4,5,6,7 at 0:00:00 (18ms) : encountered overlapping frame, audio skew is +18ms
001003:0020 DEBUG: Code 3221225861 at R/Ru3B(Mxaw 4&z'5FC}$>4::121262371
001003:0020 DEBUG: Code 3221225861 at ]I}b{0 4_E'3uc%{:213130559
001003:0020 DEBUG: Code 3221225628 at R/Ru3B(Mxaw 4&z'5FC}$>4::121262371
001003:0020 DEBUG: Code 3221225628 at ]I}b{0 4_E'3uc%{:213130559
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '32617592832'
001003:0020 DEBUG: Code 3221225653 at R/Ru3B(Mxaw 4&z'5FC}$>4::121262371
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '32617592832'
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '33042333696'
002003:0000 Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '33042333696'
DEBUG: Code 3221225861 at _worNE:(,lg'T'0g]I:29394896
001003:0020 DEBUG: Code 3221225861 at _worNE:(,lg'T'0g]I:213131502
001003:0020 DEBUG: Code 16133952 at %>PdCTzv+:fz/M&2tT6A:121261773
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '33042333696'
001003:0020 DEBUG: Code 0 at wjQpM6}A<vw#Y6gW%jhaj:121268972
001003:0020 DEBUG: Code 0 at %!k)+mE5*K=0a{[rrLdZ:29394022
001003:0020 DEBUG: Code 0 at %!k)+mE5*K=0a{[rrLdZ:29404878
001003:0020 DEBUG: Code 0 at %!k)+mE5*K=0a{[rrLdZ:29405384
001003:0020 DEBUG: Code 0 at %!k)+mE5*K=0a{[rrLdZ:29403383
001003:0020 DEBUG: Code 0 at i/H}:?)1\gS3zNV0E<wE:213141208
001003:0020 DEBUG: Code 0 at 4~H6v`PgnVj9jz^b:213132537
001003:0020 DEBUG: Code 0 at 1Cb7{tIyNy#gJL&S):29396207
001003:0020 DEBUG: Code 0 at 1Cb7{tIyNy#gJL&S):121264257
001003:0020 DEBUG: Code 0 at 1Cb7{tIyNy#gJL&S):213130490
---- Failed G:/Video4k/D/Dune- Part Two (2024)/Dune- Part Two-FPL_MainFeature_t00.mkv
ch_0        4570716150000 0
ch_1        4571662095000 0
ch_2        4572608040000 0
ch_3        4573193625000 0
ch_4        4574139570000 0
ch_5        4575085515000 0
ch_6        4576031460000 0
ch_7        4576977405000 0
mt=000001E7DC1E6B80 n=26
s=0 n=1 o=33042333696
    0 814987 000001  4576977405000       45045000 9F20198E 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E80000029E420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
s=1 n=1 o=33035323392
    1    324 000001  4576977000000         900000 41E14793 B0A26D3870276062607E609C4A6FB6C7B97413A175E891529B75B8ADFC6DF339246F34E3C2C88819EA4C526B8B4FACFC3AF541D1B58760D1E3E8390E15558E0B4E14E5C3799F2DD3248D28A30CD85430C14FB795A8FD8800D2C40F860F853A9D4F6ED36B01C83297F8A52F90F833985D0335968DDD91260BE34A532A8C5E10A6
s=2 n=1 o=33037092864
    2   1792 000001  4576988160000       34560000 9D857321 0B770A9B1E30E1DFFCE492500003F01FF5978584E8787E1911C58438A4E1557095FBE4B49F2B4AF9F3E550A13F4B4A9575915E144AEFE16B554A95885994A0890E229AEA72BEB241F51B906B567EA953A855DED2873A13E850D515A3BDFA5AFDA5AD715A9A6FA8E77CE9F3DA50DF41B75DED775395917E42DB9B0E6B3F54F953
s=3 n=1 o=33037271040
    3   2560 000001  4576988160000       34560000 92CB3998 0B77047B2430E1FFE4E492500003FF2955E186186110EB457CFAE267D4A9AB7D494A47F621C2AE972BB7D0D2BE76F9EC37B0D33A7D0DED2A6E7625ACFD6AEA4FD325AD5DCC6A6E973A7CB953E7CF9FA4AEFB5534DE0C7D21FA6535DCE84AAD2BDA6B9F3DB899F3AA4E93427E354D6AEFDF2654F952A2CFC8575CFB3434AF9ED9
s=4 n=1 o=33037271040
    4   2560 000001  4576988160000       34560000 04121DC3 0B77B1A02430E1FC11CBC924A00007E0F2EBC30C30C22C42810D3BEA699F51B0FD32871121DC550A65276FDCBEAEF9F527B5DF3A7D5E0D79D0ABB97CF9EEC535A9A586A9F2656992D34AFAB3F52FD4AB7E45F48AEFBC12AA3D2A55E942AEFA142A4FA0D844A9FA0854D2C518B9F3E4E95F5286AA93E7CF9F3E835E13EA696767
s=5 n=1 o=33037271040
    5   2560 000001  4576988160000       34560000 D12AB397 0B7745622430E1FFFCE492500003FFD995E1861861161F3FB6BE2264CFB329B8FC6245F761A9B031AEB7D4D2C2A6A693E7CA9F577D5D52674EAB3B534DD2A4B5D339A6F94C374FC8BDADAE6EB5559DAA4C975B99FD954F4E1A54D75AAF7CF92BE850A73F54AA957A50763DAE9A13D7D5ABD67CA9F6F721D77F0E13E88A68E87F
s=6 n=1 o=33037271040
    6   2560 000001  4576988160000       34560000 1FF70DE0 0B778A9B2430E1FFE4E492500003FF2955E186186110EB457CFAE267D0A9C354F94A48772BC37CA6722A6A5FA644F9EBF730D4D37D0DD3A4CEAB42869C8A654A6BA9B74A8D77CFD73A7CB953E7CFD329AEFB5BE77DA24B215A67B5DEE84AAD2BA730DF41B8F9ED77CF952A7CE9ED6AEFDEBF7D469BE54FC85754FA8EC4B0D2BF
s=7 n=1 o=33037277184
    7   2560 000001  4576988160000       34560000 2C170BC7 0B7768182430E1FFECE492500003FF6955E1861861111EC57CFE1AA7D5E7437EE54A88772BD77E42722A6A69A674FA13E7CFC853AEB9F3A74FAB5686ED4AA7CA9F3E854A942A550ABA7CB953E7D0D5A4D89A93F4DE0D7371FA67B5E8ED18BD2BE7CBA94686FDCBE7CFC9257CF9F3DB74DED786E2BBE555C8C254FAB5754F9CC3
s=8 n=1 o=33042333696
    8     30 000011  4577067495000       22522500 463DA641 16000B078004381006AB0000000017000A01000287031B0274007A800000
s=9 n=0 o=33042333696
s=10 n=1 o=33042333696
   10     30 000011  4577382810000       22522500 47562ECE 16000B078004381004CF0000000017000A0100027E031A02870086800000
s=11 n=0 o=33042333696
s=12 n=1 o=33042333696
   12     30 000011  4577067495000       22522500 C159F34F 16000B078004381004C50000000017000A01000218031A034D0086800000
s=13 n=0 o=33042333696
s=14 n=1 o=33042333696
   14     30 000011  4577472900000       22522500 0180D64B 16000B0780043810036D0000000017000A010001D2036503D8003B800000
s=15 n=0 o=33042333696
s=16 n=1 o=33042333696
   16     30 000011  4577022450000       22522500 F40F910C 16000B078004381004F10000000017000A010001AA0365042A003B800000
s=17 n=0 o=33042333696
s=18 n=0 o=33042333696
s=19 n=0 o=33042333696
s=20 n=1 o=33042333696
   20     30 000011  4577472900000       22522500 AFAA17AE 16000B078004381003BD0000000017000A010001F90317038C007E800000
s=21 n=0 o=33042333696
s=22 n=0 o=33042333696
s=23 n=0 o=33042333696
s=24 n=0 o=33042333696
s=25 n=0 o=33042333696
mt=000001E7DC227B40 n=26
    0 203835 000008  4576887315000       45045000 39BF75B4 00000003460150000000094401C172438D63B240000000084E01010304004080000000151001E00A5677085621308E800000030000030003260000737A10014784014ACEE10AC426C86E4912894211E9157D7F97F465F8198D9CEB43FEBC6617F332F98CD3863F61541D67323539FAB152093A84002137E1838048D3CD41C53B
s=1 n=48 o=33035323392
    1    316 000000  4576977900000         900000 255E6FF4 D09E6D6070276061607D60982660DB3AD2A8B3371E9406198FAEAEAF02792B9E986FCFCF7FC7AA87F024EDE1B8411E78CEAA7562189531B5AA16C2A2EA39CBBD0CA437E8A944BEA972AB4F4F5E4A041BA1474C99DD6C7C000CDE5639085FEA943A89E1F25AE88672B4635864D4F4CD1AB99F6EC93550724634EC73DD2AE2BE58
    1    316 000000  4576978800000         900000 983F62C3 109E6D887026605F607B60981CB7A58A946D4ACD10EEEA92CBA29BB0C77D24E7B0D649754E093827A876B9BF570A1398D2362B91AA3844A419DF8B0336D43310FA436DBCCA1C7A3891861D10A1CB8C75D921B213F9DB4F082DEF86C2BF4E11EE0CDA981A572899FE4777A70AC544CC0058DE33D5D5B7CC575464D52F0BFB291E
    1    310 000000  4576979700000         900000 4C0EF665 309B6DB07026605F607A609518CC8D4B73D3FEDC6ED554CD5CDFE89AB8EE36FEC0F32F0AAC14E2E3BCD49A6CBF6AFD37C0EC92CA1D29C198D4D23EC9FEACD5AB70096BA7B3FA89F81419DB531863556E13D473A36000A1452B3E0E84D0BEF6B356829AF34BD250D44291245499C2AD5F185E59B8F83F8D8A70CD9CB590C64074
    1    316 000000  4576980600000         900000 65F14AE3 509E6DD87026605F607A60983A6F915B623A81A9CB2376DCDF982C75B837FB0AB27A1830CBAA9A86FEFD5644AF1FCA6275769357864EB562251AF48A1DEF42C4A1468767D3A35D4E5E92FE90C657CC59BF4C3F44E400B34960D77EDD8C452B5C6A4DFA4AD61E2BE41937BE4E2D4DB599B2641F151FF14E28DCC9C5866F3FF0A8
    1    314 000000  4576981500000         900000 E9C2F448 709D6E0070276062607D60970BBC1A0ACE9AD76B3B5A10703792CD9876CD55A41F0F911AAB3D67F3964F1B384E79C730AA936777A4D448C714AA0CE31F9D9D2B905DAB789C3164CCD22566F42ADC4542C95B03353C50D900D301785A41C9B1ED66DAD595B53C99E8BB2512DEF03497D95B85E6AAD4130859BA3059058EEF2367
    1    324 000000  4576982400000         900000 DE6B0559 A0A26E2870276062607D609C386A88CC63C6BF93488C5D3228B24C189E016ABD796F428A1596BA1B47C9AD445BEAE4156FA809C431F4311059A084A778436331A0ABD155475D7185F01EA1C53ACD8B0C349C3BACF41AB10066A20F19F215DAB9931E7DEB4C5A271FFEA0BDD86C157091FF194DCDC5EC195FDA8038E818969119
    1    312 000000  4576983300000         900000 EE156146 A09C6E507027605F607B60968111927E76F37A9231E401C2AC05FC2F9C8E974521756F5B6BE5264C3A70DEA33E1CF920CB719BC1B57CEA3ED638534725D18A7223473D074246AAD05A184EB4A4F4F506F527A5B8771653A031C2338BBF98635740DEDD23891EF38A8E081D2E0D60DAE4CB952C28BB060EA9D56A1B550E79618F
    1    338 000000  4576984200000         900000 F3AA5529 80A96E7870256062608060A3824035F8EEFE6153CEAA42C06C4C3E72D1C0E560FF43B19BE93299A1089C8A51A846E830D4B49FC281EC86358FD0F122E87721D4FE350ADDF8E335C6F7E60222A076C9B395429800B5C782400020052B6730C22099C5499D8CF918A9037210BE91492D5EFE46A2F217D112FDA612E9DC738720D6
    1    310 000000  4576985100000         900000 165CF302 509B6EA07023605D607960953C21A0C787D9A853D376025C0BA83FC318DAFBC15B989BA92721C49894348CC47EA3BD5CC141D6E55E9AA8FBBAA6A85F1642CD77D282A1C789DFF4F95D07A792D72DBE083AF7683D2D6BF5EF6896EB1358EE3788A576D9FCD4344ADC33D4803C1D1D04498F249FB3F85F3531739B50D74B08D311
    1    304 000000  4576986000000         900000 04A93BA0 D0986EC87023605E607860924E9B292BC905BD35380E6ACB0AF7933C4EB21612CA1C4CB047C0F8242914735816CA6530C81AB5F82B05A61C6EFDC7A712F131C507CD0F8F1FC7FA86763E7FB910738860ED0A695D6EF539334C4D04E7DD6514EA123C4A1661EA92996450B2E4DE32F1A51F7E6A55BDFD40C86F97417F78C7E86D
    1    334 000000  4576986900000         900000 978E6400 30A76EF0702A606C608660A181BC24AFB6C0AFA8E3C3F41185E85891C0B97C9A5FB85AE58251138C44D53F8DEF6DA24ADCABBB0D38C9ADE3FD94B6E131339F25F592BA3D3993AA113E6B6580A2178D0FEEB37BBB1ADC1CA84954A6BBC0006CCA81C428A13A005608075D381A0688A383045275D456E6CAE6E554D7300984F09E
    1    310 000000  4576987800000         900000 A6F95ACD 409B6F186023605F60796095359725E2B4DF6CD5396487D8D0D4C5B694D645590EE9FD9C00BD44381402A5E664E92A4A76F760115294C14F71FCDA8C5B342FF7DC33CFA766B62D4AAD61B90335B3386086CF49E5DDE543D1C7A2F5DFE4D9C61C89E0766EF6A4DE6CD2D966CD93B7775EFACFBF1FCC2E7779D1BC953D23C04092
    1    324 000000  4576988700000         900000 BA561EBC A0A26F406023605F6079609C461576296FEE7606A67B5DA2635C17359A0E48D96A315891F13E39F552DAADB65211A8D6525312BE3D6F20505F450E15D39C07DC38C9FE0E1B393B3D81EAD694808B70003C9249CEC619A5114DFAAC951A27DD0F297EFB037F4BA3E2EF775A0FD95EE585FB91D2C1BD89E43DA1E0F1E0B43E4232
    1    308 000000  4576989600000         900000 9A471FA1 209A6F686023605E6079609460D891A49E3C3220ADAFC7FE84A6EA8B80A79CF1C55496341CB54C22A6955641F9E642EAA9BA714D897A9CC12339D54CEFBAF620EB9836FB1E31EC53E44E048554481FFABC4C63B7FD540A1D8F561DA2F1BB443F54B74E2A049DBC2887D19A6E5DFEEE7D9208E7774F953EEC73DBE7F07D0DC96B
    1    312 000000  4576990500000         900000 11669158 009C6F906023605F60796096487769663F9F5AB214BEC529A1F83CE12B7A336130CA82E1A7FFC4C2E83D6560FA7BDAF41217F1DB4A5C076B1FA68116C63FD393AAF25AE4125FF2C3FBA9D6E1F1AE2980631C1B0E36F75D44A76C55B2E1CCBF4D4BDD9A66675C72A1A9E4787A15EA5D19571B3144DD7C5DEB37ED127AC3119F6C
    1    312 000000  4576991400000         900000 BA10DC68 A09C6FB87023605E607960960667F231DEF3347AD7ED85C4091C9B8383A2AC9C8EE6E06755C7124281538B163B8EBD6C34795AAF0FCE6AD2EA469E905C118659D67483F69DE0E4E6ABA6A59F1524C7D041AE29F1361E6EF37878F5DA7AC5E1E3E1732ED57E63E33542D1C34B4254067CBADD5D266310E7963F9298DA9067EB39
    1    310 000000  4576992300000         900000 F19BF32D 409B6FE06024605F607960956A78C9C9E1E8974A80AE4F507980420C5E89A815DCC0518B37B5F546ED3A10FBFCA9488D54727386A261BE6D3A57CE440E3494455267E87441C94A8FA2A5317D56A90C9E9ADA953E1AF7E09540269F5774557DD16497428DF50528961B17A55135EA59D32AC299A369D6DB593FBE68EB0B10DE79
    1    324 000000  4576993200000         900000 5D968BD8 70A2700870256062607F609C80889470C791A79A6C527748D04F0C8AFD9ACF863A7DF112957EBA68A388BDB73A8D81A6CD55CF18A911707C6364A2BAF947EA06CA94C7FA3D96DA3ABB4F475D2C67CCF4D54D7000DF8210D86C1D2CEC55AF1E6FFB44A98476206DFCA3565F2113DD4DFC93A59ECDDE0EA1C8B757548822342A64
    1    314 000000  4576994100000         900000 1D009ABC A09D703060256060607D6097808462837ED5DE2F0D43A03A573FC88C8B291572FC785060B445EE53DB38CBCC5EF1D4A4E519FCE8254BFA46E21E3F0CA35CDC7F78D7813E1E169074E8443ED31EB4B50FEBDE7980208F5688A24A096F5977B7A87990399962B4BE7091D5477933852C3B1E96CF40C5F6F3F172653318E8AA8A63
    1    340 000000  4576995000000         900000 CD9F03EA 40AA705860266064608160A4824028B67104E23D2BBBC7B007087DCE11423193A50F78567047F6CA5148BF7D50E8A81AF3BCDFB6A0C0BEE19C254D5FD5E1CE187D97EC2495BF4271EBA43C17E4368CBCE105ABF6C0003F5C8240002002DA5B70DF3AE0FE965231EFC9D675D1ECAB5C1B8616F7E538E0F3B0370AB2350F12B305
    1    320 000000  4576995900000         900000 B371AA27 10A070807025E061F870607CE098F87036801AC0728514B61213B15E10EC00FA945836BA31C612A150255DF9A7210CA385891FE8563662364B163D6D2323366B16935908E6F270CB1C41F830E8B2E9F592890C39EAAB50008CF31254953E31026315F962A6D3FCD42A66C6C0EDA5494F24F2A792A981E99D2184E1D3BBF8A7FA
    1    324 000000  4576996800000         900000 30FCFA95 C0A270A860246060607C609C1ED1388B231FA607A69AA5150BFB67657E16C1FFE2F71D14FEDCB393255AD1285622CB9E703D80B1AE00C11D02E5B846FE7A2A43E252FD9F488709E4FC10902836B08D8DC44085C526A1477AF72D09BDE663AC7A5F751229145598A39E6D6DD7051154F98ECF20F1C096F23D747971347E1CAED5
    1    322 000000  4576997700000         900000 08F1B18D 60A170D060256062607E609B24CE4FE853551D9394035A8C449A546BD2C8824B96C84B248EA4DAA824169685B0A1FEC3FD45D3E19472C51AEF72AB4E57C7829176CE8CCF24997DA7881532C5A45437FD7314E8007089133570579B9B00B1B8320D611EF489E833E0445BBE238A01AB532D3AD7F7755D5475357E8CFAFD35D522
    1    310 000000  4576998600000         900000 C634E451 609B70F86023605E607A60956F792FDBFC9F0F93353465B5DA6CE7FB7F99D59C7AD012647BCBB64ACBFB5E2D68C1019B9D74A1305ED786ADFA928D4EE524F1E3CFBBAE34C85379649CC5721258ABD90059CA6D339B3ED2237ADF8377136286228929B507C30C13EDD363FDADBBC7B7725A9E066F50A7568E0C1F6A2A6D7AE1D3
    1    306 000000  4576999500000         900000 A396D1CA 409971206023605E60786093527F550E8B15C5471EC70C1697AAA1C7AE776159A5521482461263A618B7BB71F9EE89F8DEF3F88F3BC4433577D3F7DD0E635E490193F0D14DA25EE8DE18FC82F916A364141E303679A577F366712A7F88E7F8B8F797E94FE2C0228D2A304DAEA290B9A64E656C062AB075B896449DF9D0CC2FE3
    1    310 000000  4577000400000         900000 F766FEBE 709B714870246060607A60952FAA38E0A87A30EEF8952421E07761FEAA4C78B615BD237FFE5C7B809B231F8E923951E91BECB6789349088548706F1813ACB5397CDE952528AFEA2EA8D1D45ED34A606C440046C80897BD2487706802E304292896B91FA4F6166FCD98DD0E333559A1B1E47987753E688865BEFF69B97C7B6155
    1    314 000000  4577001300000         900000 4263F501 809D717060246060607B609700457CD90693BC507510DD95FAE7078FD0462F241A1C18906F33EA8A510F6C82D16FEB6B199EF65F0E6DF569B427AD03B6CC7247FB8B2322FC0903C77657617B63FACFB1D032F4122284F01F61A75DACFC2A94B6D9C754547635983C5597B57AABA3A66103A94FE7519539D9345C3D708065B3C9
    1    326 000000  4577002200000         900000 B24E2431 D0A3719860246062607D609D294CDC25EB5E8C20537D22C37F8B231C8D2F2F3E0D5FE52AA6D94ADACFFD61D4C62D630031458139F13D4AA79D82FA5691BA10B93D6627B881B8C091B2C50B03449F976FE0002A8D808881EF76D6C6770D28F9B3EECDACC541CFF5F79F0F976E8969EC64ABEE5292F80C2E9BCF61F3F5F9BDE978
    1    388 000000  4577003100000         900000 AE2739D3 20C271C070246061607B609C7D8BEF8859E0B3364101AE1C6B645F2FF391FE48A15F367528D3A1ABB55AE571BCC49072E2C15691853E5B86BCDE0DC6D124760453126AD4B2CF13751CB14319FE334F354000B8FC80846137D9F2AAF275783F488315537E7288FF571B360FC4BE67D38A6094C09F0F575EC76D530C5164B2524F
    1    310 000000  4577004000000         900000 130061DB 709B71E87022605D607860951D1FF09E9107719E3FEE5A6DF7FD963D98E53862DED71D33DF087C87A32BCC9C8662C4E0622BDADC50FEDC58D0DDA24859FC652E90497258DEF8DE7007BD15B2CAE0EF5680426282E28BC659D22B62D3F6D2CEADAB6D2E66BCA84EDF047A8BFEF5AEDB1DB0D30AC0372F087BD12FABF3AADD77B8
    1    312 000000  4577004900000         900000 EC89384D 409C72107023605E607960965556C5FD40EFFDA72C686EA0EA519A59A5913E77DA8F99C6F99FB2BA516EBC5CBB2B97CA949B3D52ADA28A70D5966CE53FDF7E9D8D4417049FF246C70C6E312D8A673A005D5A7F598D153F60B82975EDBD52D569F8F284305522CE3CF20586AA0C8E9A4A9CEDC0927C3C5F2598A311C5ADBAE85D
The drive is really struggling with that disc. Errors like this:
make me think the drive isn't getting enough power. Or maybe the lasers are dirty. From the perspective of the operating system, the OS asked the drive to read a spot on the disc and after waiting for a while to get the data, the OS eventually gave up waiting.
Sometimes LG drives need to be power cycled. If the drive is internal in your computer, you'll have to power off the system, a reboot won't be enough.
