VUK found in KeyDB_Helper but makeMKV can't decrypt
Loki7571
#1 Post by Loki7571 » Tue Dec 23, 2025 11:03 pm
I use SamuriHL's KeyDBTool for Windows and search my disc ID there and it found the key there like this:
[KEYDB_STATUS]: (VALIDATED)
[MakeMKV SUPPORTED]: TRUE
I have already copied the newest keydb.cfg file to my C:\Users\USER\.MakeMKV directory but makeMKV stills fails to decrypt:
What could be the reason?
Thanks in advance
Re: VUK found in KeyDB_Helper but makeMKV can't decrypt
#2 Post by MartyMcNuts » Tue Dec 23, 2025 11:19 pm
Loki7571 wrote: Tue Dec 23, 2025 11:03 pm I use SamuriHL's KeyDBTool for Windows and search my disc ID there and it found the key there like this:
Thanks in advance
You did extract the file from the zip?
It is a physical disc and not an ISO?
Loki7571
#3 Post by Loki7571 » Wed Dec 24, 2025 12:51 am
I extracted the cfg file from zip and it is a physical disc…
