Can't rip DVD with empty AUDIO_TS and VIDEO_TS directories but DVD plays fine
bmcneely0
Post by bmcneely0 » Tue Dec 23, 2025 6:53 pm
I'm not sure this is specific to Mac but since that's my platform I'll start here. I'm running
MacOS 26.2
MakeMKV 1.18.1 [darwin(arm64-release)]
libdvdcss 1.4.3 (installed from homebrew)
Here's my situation. I have a set of DVDs (Jeremiah Season 2) that produces the following behavior:
1. When you do a ls on the drive from Terminal it shows the AUDIO_TS and VIDEO_TS directories, but they are empty. Same behavior if you do sudo ls -a
2. Doing a Get Info from Drive Utility does show that there should be 16 files on it
Volume name : DVDVIDEO
Volume type : Unknown
BSD device node : disk5
Mount point : /Volumes/DVDVIDEO
File system : Universal Disk Format (UDF)
Connection : USB
Device tree path : IODeviceTree:/arm-io/usb-drd1@2280000/usb-drd1-port-hs@01100000
Writable : No
Is case-sensitive : No
Volume capacity : 4,434,176,000
Available space (Purgeable + Free) : 0
Purgeable space : 0
Free space : 0
Used space : 4,434,176,000
File count : 16
Owners enabled : No
Is encrypted : No
System Integrity Protection supported : No
Can be verified : No
Can be repaired : No
Bootable : No
Journaled : No
Disk number : 5
Media name : HL-DT-ST DVDRW GX30N Media
Media type : DVD-ROM
Ejectable : Yes
Solid state : No
S.M.A.R.T. status : Not Supported
The disc plays fine with the DVD Player app so I know there's content there. When I try to use MakeMKV (or Handbrake for that matter) they both choke. Handbrake just automatically closes and MakeMKV just churns. Any thoughts?
bmcneely0
Re: Can't rip DVD with empty AUDIO_TS and VIDEO_TS directories but DVD plays fine
Post by bmcneely0 » Sun Feb 15, 2026 6:29 pm
I wanted to report that I found a solution to this. I kept playing around with the google search words and found this answer
Change DVD Opening Mode: In the Open Disc dialog or settings, change the DVD opening mode from "Auto" to "CellTrim".
I accomplished this by
  • Opening MakeMKV
  • File -> Preferences
  • Select the Protection tab
  • Under DVD change the DVD structure protection removal method from Auto to CellTrim (there are others you can try but I tried this first and it worked like a champ).
  • Click Apply
  • Click OK
This was done on MakeMKV 1.18.3 on MacOS 26.3
Post by dcoke22 » Fri Feb 20, 2026 12:21 pm
There's a post on this forum about MakeMKV's various DVD Opening Modes.
