Blade Runner Final Cut (disc 3) - Navigation Errors
eeyorehoop
Post by eeyorehoop »
I've run into an issue trying to rip disc 3 of the Blade Runner 5-Disc Ultimate Collector's Edition. Specifically, MakeMKV is skipping the theatrical, international, and director's cuts of the film. It's able to rip the other content, i.e. the Ridley Scott intros for each of versions.
I've searched the forum but haven't found info on this specific disc. I did try Manual Mode (as best I understand how) as others have suggested to workaround this kind of error, but I get the same outcome.
Below is info from MakeMKV. I'm on MacOS 12.6 and the disc plays fine with VLC and a regular blu-ray player. Any suggestions or pointers someone can offer?
** MAKEMKV DRIVE & DISC INFO**
OS device name: /dev/rdisk11
Current profile: DVD-ROM
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: KLKL5A93237
Firmware date: 2117-04-25 17:56
Highest AACS version: 76
Firmware version: 1.00
Disc Information
Label: BLADE_RUNNER_ARCHIVAL_VERSIONS
Timestamp: 2007-10-19 19:15:37
Protection: CSS/CPPM
Data capacity: 6.49 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
** MAKEMKV OUTPUT **
MakeMKV v1.17.2 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS60 1.00 KLKL5A93237d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.00 KLKL5A93237' at offset '4729300992'
Cells 55-55 were removed from title end
Complex multiplex encountered - 6 cells and 1507 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 (1:56:31) was skipped due to navigation error
Complex multiplex encountered - 6 cells and 1520 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #2 (1:57:34) was skipped due to navigation error
Title #3 (1:57:18) was skipped due to navigation error
Cells 2-2 were removed from title end
Title #4 was added (1 cell(s), 0:00:37)
Cells 3-3 were removed from title end
Title #5 was added (2 cell(s), 0:00:22)
Title #7 was added (2 cell(s), 0:00:26)
Title #8 has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #9 has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #10 was added (1 cell(s), 0:00:21)
Title #12 was added (1 cell(s), 0:01:18)
Title #13 was added (1 cell(s), 0:00:29)
Title #14 was added (1 cell(s), 0:00:28)
Title #15 was added (1 cell(s), 0:00:34)
Audio stream #0 looks empty and was skipped
Re: Blade Runner Final Cut (disc 3) - Navigation Errors
eeyorehoop wrote: Sat Oct 29, 2022 3:15 pm Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.00 KLKL5A93237' at offset '4729300992'
That error means the drive was unable to correctly read a part of the disc. Try gently cleaning the disc and trying again.
Additionally, there are different DVD opening modes. Trying a different one might yield different results.
DavieB
Post by DavieB »
I know it's a couple of years later, but with the recent news about Disc Rot, I revisited my "Blade Runner" set. I have the five-disc set in the collectible attaché case. I had problems ripping years ago when I was new and trying to do it in Handbrake. The Archival disc wouldn't rip correctly. At that time I attributed it to the branching nature of the three versions on the disc.
I re-ripped a lot of my discs a year or two ago, this time in MKV format with subtitles and commentaries and all the special features. "Blade Runner" wouldn't rip again, dammit. Branching? Damaged Disc? At least I had the Final Cut and the documentary extras.
When the Disc Rot info was revealed the other day I tried again. Discs 1 and 2 both were fine, but once again, disc 3 and disc 5 both failed. I tried watching the three versions on disc 3 and all three fail at exactly the same point, about an hour and seventeen minutes into the picture. I haven't tried watching disc 5.
I guess I'm going to have to get in touch with Warner Bros.
Now to retry my "Forbidden Hollywood" sets. Those were temperamental in MakeMKV, too, and are on the "Disc Rot" list.
Mr. Red
Post by Mr. Red »
I successfully ripped all 5 discs of my Ultimate Edition a few years ago. But if they are on the rot list maybe I can ask Warner for a set of Blu-ray discs 8)
After proof of ownership, Warner send me Blu-ray replacements for a few rotten HD DVDs a couple years ago. No need to send the old discs in. In that regard Warner is (or at least was) very pro consumer.
TMD12
Post by TMD12 »
I was having the exact same problems as eeyorehoop when I was using my Blu Ray drive to read the disc. However, when I tried with my USB DVD drive, it worked perfectly. Don't know what it could be. Maybe Blu Ray drives have trouble with how the disc was created and the features that it supports.
TMD12
Post by TMD12 »
TMD12 wrote: Tue Jul 22, 2025 8:12 am I was having the exact same problems as eeyorehoop when I was using my Blu Ray drive to read the disc. However, when I tried with my USB DVD drive, it worked perfectly. Don't know what it could be. Maybe Blu Ray drives have trouble with how the disc was created and the features that it supports.
Quick update:
The disc completely failed to rip right at the very end. Gonna try with some older drives. We’ll see if that changes anything.
Car'a'carn
Post by Car'a'carn »
I'm having the same problem with disc 3. Did you ever find a workaround?
olevelo
Post by olevelo »
I just happened to finally rip my copy of this, and had no issue with disc 3. I did have issues with Disc 4 (DVD) though. Couldn't get MakeMKV to read it at all. I have the 4k version though which also has that disc and that one worked fine. The tricky part was figuring out which version was which on disc 3! Also I spent awhile trying to find one of the special features on Disc 4 only to realize it's just audio interviews. I guess no way to rip them. :(
