Hi everyone,
This is one disk that just refuses to rip for me. When I play it back though my AC Ryan, it plays
at a faster speed and the dialog sounds like a bunch of chipmunks talking. I thought it might be the size of the file, but I have plenty of other files just as big. Anyone know what the problem is?
Solaris: Criterion Collection
Smithcraft
Re: Solaris: Criterion Collection
BD or DVD?
MediaInfo report?
SC
MediaInfo report?
SC
It's a BD.Smithcraft wrote:BD or DVD?
MediaInfo report?
SC
I'll try and get the mediainfo report up.
What will that tell you, anyway? Sorry for the newb question.
Smithcraft
here 'tis:
General
Unique ID : 233058277583049474131538230959523495436 (0xAF55643D2CB46C15477284FD02EFFE0C)
Complete name : /Solaris.mkv
Format : Matroska
Format version : Version 2
File size : 28.3 GiB
Duration : 2h 46mn
Overall bit rate mode : Variable
Overall bit rate : 24.2 Mbps
Movie name : Solaris
Encoded date : UTC 2012-03-03 10:46:29
Writing application : MakeMKV v1.7.1 darwin(x86-release)
Writing library : libmakemkv v1.7.1 (1.2.0/1.1.0) darwin(x86-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 46mn
Bit rate mode : Variable
Maximum bit rate : 37.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : Yes
Forced : No
Audio #1
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 2h 46mn
Bit rate mode : Constant
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Title : 1/0
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 46mn
Bit rate : 192 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 229 MiB (1%)
Title : 1/0
Language : English
Default : No
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
General
Format : Matroska
Duration : 2h 46mn
Video
Format : AVC
Duration : 2h 46mn
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio #1
Format : PCM
Duration : 2h 46mn
Bit depth : 24 bits
Title : 1/0
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 46mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Title : 1/0
Language : English
Default : No
Forced : No
Text
Format : PGS
Language : English
Default : Yes
Forced : No
Smithcraft
The frame rate is correct. Can you play it with VLC on your computer?
SC
SC
I can play the video on vlc without the stutter and it has, obviously, no audio since it's LPCM.
Playing on my AC Ryan has the audio but the whole movie looks like it's running at a faster speed. Speed up voices and stuttering.
I will try and rip the whole disc and see if that works.
My only other alternative would be to buy a multi-region player I guess, or a PC.
setarip_old
@dj2hynes
Hi!
The following is noted at at least 4 review websites:
Based on what you described, it sounds like someone made a less than perfectly successful effort to add a second audiostream...
Hi!
Perhaps your problem is related to the SECOND audiostream noted by MediaInfo (English Single channel AC3).There is only one audio track on this Blu-ray disc: Russian LPCM 1.0. For the record, Criterion have provided optional English subtitles for the main feature.
I tried a complete disc rip instead of makemkv. Works perfectly, except the sound plays only on the left channel.
Anyone know how to rip a bluray iso on a mac? Seems my only solution now.
Smithcraft
You can rip(back-up in this case) the BD with MakeMKV.
SC
SC
If you are trying to watch this movie using a Mac then MPlayerX will play back mono LPCM unlike VLC which will not unless it is stereo for some reason. http://mplayerx.org
Also worth a mention is MPlayer OSX Extended http://www.mplayerosx.ch and a fork https://sites.google.com/site/hermihg/ but these have not been updated in awhile.
firionicable
Do you think there might be a problem with the player where you are playing it with background noises? Since it works with VLC, everything should be fine.
