LG WP50NB40 Recovery Flashing via CLI
jayawrrr
Post by jayawrrr »
Been trying to unlock libredrive on my WP50NB40 based on the CLI procedures outlined in the ultimate guide.
viewtopic.php?f=16&t=19634
I first flashed BP50NB40-NB50-1.03MK, then BP60NB10 1.02MK. Both steps reported success, but the drive is still showing as `Status: Possible, not yet enabled`.
Looking at some of the other threads related to WP50NB40, it sounds like the second flash requires the RECOVERY option from the SDFTool Flasher GUI. However, I don't have ready access to a Windows machine rn to run that tool and I don't see an equivalent option in the help docs for the CLI.
Does anybody know what the equivalent settings would be to perform a RECOVERY via the CLI? Or is there something else that I'm totally missing?
My drive info is as follows:
OS device name: /dev/rdisk8
Product: BD-RE WP50NB40
Revision: 1.03
Serial number:
Firmware date: 2121-07-08 16:09
Highest AACS version: 81
Re: LG WP50NB40 Recovery Flashing via CLI
jayawrrr wrote: Sun Dec 21, 2025 2:21 am Been trying to unlock libredrive on my WP50NB40 based on the CLI procedures outlined in the ultimate guide.
Revision: 1.03
Serial number:
If using Linux you need to use an older version of MakeMKV for flashing as the latest version for Linux has issues. There are a few posts about this.
jayawrrr
Post by jayawrrr »
I'm using MacOS with MakeMKV version 1.17.7.
These are the commands that I ran to flash:
./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash full main -i ~/Desktop/flash/BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash full main -i ~/Desktop/flash/BP60NB10/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
jayawrrr wrote: Sun Dec 21, 2025 11:06 pm I'm using MacOS with MakeMKV version 1.17.7.
change main to enc for the first flash.
jayawrrr
Post by jayawrrr »
Changed main to enc for the first flash, but still showing "Status: Possible, not yet enabled". Performed full system reboot and no change. Still won't read 4k discs :(
Current commands:
./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash full enc -i ~/Desktop/flash/BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
jayawrrr wrote: Mon Dec 22, 2025 1:15 am Changed main to enc for the first flash, but still showing "Status: Possible, not yet enabled". Performed full system reboot and no change. Still won't read 4k discs :(
Current commands:
remove full, it's not needed. should be rawflash enc.
post the output.
jayawrrr
Post by jayawrrr »
Progress! It looks like the first flash finally worked! The drive info is now as follows:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM2221U15627
Firmware version: 1.03
It still will not read the UHD disc that I'm testing with. I assume this means that the second flash still is not working?
Below are the commands that I ran and output:
$ ./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash enc -i ~/Desktop/flash/BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
Reading input file /Users/jayawrrr/Desktop/flash/BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
Current Drive ID: HL-DT-ST_BD-RE_WP50NB40_1.03_212107081609_SIM2221U15627
Using USB chipset workaround for Desktop drive handshake
yes
100% Operation finished
Done successfully
$ ./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash full main -i ~/Desktop/flash/BP60NB10/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Reading input file /Users/jayawrrr/Desktop/flash/BP60NB10/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Flashing flags = 0x1 : 0 0 0 1 : ---- ---- ---- BOOT
Current Drive ID: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM2221U15627
yes
Done successfully
jayawrrr wrote: Mon Dec 22, 2025 6:00 am Progress! It looks like the first flash finally worked! The drive info is now as follows:
Revision: 1.03
yes
Done successfully
yes
Done successfully
From the UHD drive guide:
WP/BP50NB40 SVC NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
so the bold & underlined step is done. Flash the same firmware again using rawflash full this time which will flash with the bootloader. Then use rawflash main for the last flash with the BP60NB10 1.00_HBD firmware.
jayawrrr
Post by jayawrrr »
Success! Thanks for clarifying those commands, Marty!
For anyone else looking to unlock a WP50NB40 slim drive, these were the final commands that ended up working for me:
./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash full -i ~/Desktop/flash/BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
./makemkvcon f -d '/IOBDServices/0378CC82' -f ~/Desktop/flash/sdf.bin rawflash main -i ~/Desktop/flash/BP60NB10/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
jayawrrr wrote: Mon Dec 22, 2025 9:43 pm Success! Thanks for clarifying those commands, Marty!
Glad you're all sorted! :D
