Every disc has an Error
paul2793
Post by paul2793 » Fri Dec 19, 2025 6:40 am
I hope I'm posting this in the right area. I have been trying to rip some 4K movies tonight and every single disc I try to rip, in the middle it stops and gives an error message.
Very frustrating. It has never done this before. Any ideas?
Paul
Re: Every disc has an Error
Post by dcoke22 » Fri Dec 19, 2025 7:23 am
Have you tried power cycling your drive? Whenever my drives get into a weird state I power them off for a bit then turn them back on. My drives are external, so it is relatively easy for me to do. If your drive is internal you'll have to completely power off your computer.
Post by MartyMcNuts » Sat Dec 20, 2025 4:12 am
paul2793 wrote: Fri Dec 19, 2025 6:40 am I hope I'm posting this in the right area. I have been trying to rip some 4K movies tonight and every single disc I try to rip, in the middle it stops and gives an error message.
Paul
Start by cleaning the discs. Even if pristine, still give'em a clean!
scarbrtj
Post by scarbrtj » Mon Dec 22, 2025 9:30 pm
Polywatch has enabled me to rip many brand new discs I couldn't otherwise. It is very strange to see what looks like a perfectly clean disc have Polywatch remove a visible black residue from the surface.
Post by Coopervid » Mon Dec 22, 2025 9:38 pm
scarbrtj wrote: Mon Dec 22, 2025 9:30 pm Polywatch has enabled me to rip many brand new discs I couldn't otherwise. It is very strange to see what looks like a perfectly clean disc have Polywatch remove a visible black residue from the surface.
No product placement please. Liquid soap and warm water works perfectly.
scarbrtj
Post by scarbrtj » Tue Dec 23, 2025 2:38 am
Coopervid wrote: Mon Dec 22, 2025 9:38 pm No product placement please. Liquid soap and warm water works perfectly.
Except when it doesn't; then I've found *product placement brand REDACTED* a thing that does.
