Proper flashing procedure for Buffalo BRXL-PUS6U3B
Woody
#1 Post by Woody » Mon Dec 22, 2025 4:33 pm
As per this thread viewtopic.php?f=19&t=40461 Coopervid's advice is to "downgrade to 1.17.7 and flash BU40N 1.00." on my slim external Buffalo BRXL-PUS6U3B.
Read through the guide and will do so again. To clarify what I understand so far:
1) download SDFtool Flasher and All You Need Firmware Pack
2) flash BU40N 1.03-MK first
3) flash BU40N 1.00 next
Just a bit fuzzy on when to use write or recovery. I'm currently blaming this on a lack of coffee and sleep. Guess I'll see if there's a video tutorial out there.
Many thanks to everyone in the MakeMKV community.
Device: /dev/sr1
Manufacturer: Buffalo
Revision: BN14
Firmware date: 2121-06-21 13:33
Bus Encryption flags: 1F
Re: Proper flashing procedure for Buffalo BRXL-PUS6U3B
#2 Post by Coopervid » Mon Dec 22, 2025 5:03 pm
Looks good! :D
Woody
#3 Post by Woody » Mon Dec 22, 2025 5:11 pm
Thanks, Coopervid. So both times I just select the firmware and choose Write. ie, write 1.03, then write 1.00?
Hope you have a great holiday season.
#4 Post by Coopervid » Mon Dec 22, 2025 5:19 pm
Woody wrote: Mon Dec 22, 2025 5:11 pm Thanks, Coopervid. So both times I just select the firmware and choose Write. ie, write 1.03, then write 1.00?
Jepp! Enjoy your holiday season.
kzburner
#5 Post by kzburner » Wed Dec 31, 2025 8:42 pm
Hello, thanks for the info on this drive. I was able to pick one up and have successfully flashed it to 1.03 with the firmware in the all you need firmware pack.
I wasn't able to find the 1.00 firmware in the "all you need" pack. I did find "DE_LG BU40N_1.00.bin" in the firmware pack in this post but wasn't sure it is the correct version for the slim drive.
viewtopic.php?f=16&t=18873#p70284
#6 Post by MartyMcNuts » Wed Dec 31, 2025 10:57 pm
kzburner wrote: Wed Dec 31, 2025 8:42 pm Hello, thanks for the info on this drive. I was able to pick one up and have successfully flashed it to 1.03 with the firmware in the all you need firmware pack.
I wasn't able to find the 1.00 firmware in the "all you need" pack does anyone have the link for that? I did find "DE_LG BU40N_1.00.bin" in the firmware pack in this post but wasn't sure it is the correct version for the slim drive.
Yes, that is the correct firmware.
kzburner
#7 Post by kzburner » Thu Jan 01, 2026 5:19 am
Cheers, thanks Marty.
raymate
#8 Post by raymate » Sat Jan 24, 2026 11:05 pm
I just got this drive from Amazon.
new to all this flashing so bare with me please, have questions.
So what is 1.17.7 all about and do I need to downgrade to 1.17.7 and where do I even find this?
Or do I just ignore this 1.17.7 info and just start doing the following:
Flash - DE_LG_BU40N_1.03_MK.bin (first)
Flash again - DE_LG_BU40N_1.00.bin (second)
What the reason behind going to 1.03 then back to 1.00, isn't 1.00 older? why not use the newer 1.03?
Just to confirm I have the slim BRXL-PUS6U3B:
Manufacturer: BUFFALO
Revision: BN14
Bus encryption flags: 1F
Highest AACS version: 81
Thank you
#9 Post by MartyMcNuts » Sat Jan 24, 2026 11:32 pm
raymate wrote: Sat Jan 24, 2026 11:05 pm I just got this drive from Amazon.
Revision: BN14
Thank you
For UHD discs, MK firmware only works with MakeMKV and Xreveal. If you use other UHD ripping software, v1.00 is what you want.
raymate
#10 Post by raymate » Sun Jan 25, 2026 12:23 am
MartyMcNuts wrote: Sat Jan 24, 2026 11:32 pm
Revision: BN14
Thank you
OK, I only use MakeMKV so i shall do the 1.03
Thank you for a fast reply
houstonrocket
#11 Post by houstonrocket » Wed Jan 28, 2026 4:16 pm
Hi all, I have the same drive and have done the above.
But I have a question: is it possible to go back to 1.03 after going to 1.00?
I tried to go back to 1.03 and SDFtool Flasher showed an error dialog as soon as I clicked "Start", it asked if I wanted to Continue or Quit. I chose Quit and looks like no damage was done. I kept a copy of the error output if anyone wants to see it. Thanks for your help.
Edit/Update (2026-01-29):
After raymate's response, I again tried flashing 1.03 to replace 1.00 (using Write mode, same as last time) and did not get the immediate error dialog this time.
My guess: a) maybe I had a disc in the drive previously, or b) the drive needed to be reconnected, perhaps it was in a weird state due to reading errors from recent MakeMKV session or was a random fluke. Flashing 1.03 completed without issue and I was able to rip.
On another note, I'll mention this post regarding another difference between using 1.00 or 1.03 with BRXL-PUS6U3B, a user claimed they could not use certain burning features on 1.03 but could on 1.00: viewtopic.php?style=4&p=162898#p162898.
raymate
#12 Post by raymate » Wed Jan 28, 2026 9:20 pm
houstonrocket wrote: Wed Jan 28, 2026 4:16 pm Hi all, I have the same drive and have done the above.
Yes. I flashed mine to 1.03 then to 1.00 to see what would happen. It worked fine then I flashed it back to 1.03 and all was well. Ripped about 10 discs so far after flashing it multiple times
penguinpower81
#13 Post by penguinpower81 » Tue Mar 17, 2026 1:36 am
Were you able to flash this drive? I flash it but the firmware doesn't change.
Buffalo BRXL-PUS6U3B-TU
#14 Post by Billycar11 » Tue Mar 17, 2026 1:52 am
penguinpower81 wrote: Tue Mar 17, 2026 1:36 am Were you able to flash this drive? I flash it but the firmware doesn't change.
you most likely either leaving out or putting enc when its not needed
see guide for details below
or
email me or marty for an auto flasher
divchase
#15 Post by divchase » Fri Mar 20, 2026 1:17 am
Hi! I read this thread and I’ll be attempting to flash soon. I’m just not clear on the makeMKV 1.17.7 that’s recommend. Is This a requirement in general or only if flashing down to firmware version 1.00
Thanks !
