fedeb wrote:
Fri Dec 19, 2025 1:04 pm
can someone update the post for Linux instructions?
The MKV for linux points to 1.18.2 version viewtopic.php?f=3&t=224
But this guide viewtopic.php?f=16&t=19634 tells that we must use 1.17.7 version
How we can install 1.17.7 if the only working version is 1.18.2 ?
https://makemkv.com/download/old/
trolnator
Post by trolnator »
Hi All,
I recently purchased an ASUS_BW-16D1H-U_E116_DIDL121264WL but when I try to flash it it just says it does not have the correct drive platform.
Did I purchase the wrong device or can someone help me with this please?
Any info or help is much appreciated, thanks a lot in advance!
Kind regards,
trolnator wrote:
Sun Dec 21, 2025 8:41 pm
Hi All,
Kind regards,
It's a Pioneer drive. Post the MakeMKV drive info and libredrive info sections.
Mr_Orange
Post by Mr_Orange »
MartyMcNuts wrote:
Mon Dec 22, 2025 12:42 am
Hi All,
Kind regards,
Can these things be shucked and installed directly into a PC?
Mr_Orange wrote:
Mon Dec 22, 2025 12:45 am
Hi All,
Kind regards,
Pretty sure they can. It should be a standard SATA drive inside.
Mr_Orange
Post by Mr_Orange »
MartyMcNuts wrote:
Mon Dec 22, 2025 12:48 am
Thanks Marty. Are they:
  • UHD ready;
  • need flashing; or
  • enabled by the SDF.bin update
nicholfd
Post by nicholfd »
Mr_Orange wrote:
Mon Dec 22, 2025 12:51 am
  • UHD ready;
  • need flashing; or
Most likely will need to be flashed with software/firmware available on these forums.
No way to tell for sure until the owner posts their drive MAkeMKV info (Mfg's will change/vary the internal drive mechanism even in the same model USB chassis).
All of this model chassis I've seen have drives that can be flashed for MakeMKV/4K/UHD.
Just checked, and I have the more common US model #/version (may be exact same, if his model came from package tag/barcode) of that drive for sale, pre-flashed. Link to the "For sale" thread in my signature, along with my e-mail address.
EDIT - And yes, they can be removed from the USB chassis & installed in a desktop PC. Remove the back 2 rubber feet, and remove 2 screws. Two shells of the chassis snap apart. Verified on the drives I have for sale.
Thanks,
Frank
For sale:
4K UHD Desktop LG Drives, 4K UHD Buffalo Branded Slim LG Drives, 4K UHD LG Branded Slim LG Drives,
drives@nicholasfamilycentral.com
Check first post of each For Sale thread for current/updated availability!
LGSONE
Post by LGSONE »
G: HL-DT-ST_BD-RE__WH14NS40_1.01_211304042325_K92DAVC0827
Stumbled upon this as I just fired up this machine to back up some BR's. I purchased makeMKV in 2021; it worked well, but I'm now experiencing issues. Looks like the drive in use cannot be flashed. Is this correct? I have been reviewing this, and before I go to eBay, I wanted to check.
If it is unable and you were buying a drive today, what would be the "best"/one to get?
Thank you,
LGSONE
LGSONE wrote:
Mon Dec 22, 2025 4:21 am
Thank you,
LGSONE
Nope, too old. Manufactured in 2013 and would have the old MT1939 drive platform.
Best one to get is any Pioneer but the world's supply is dwindling fast! If you can't get a Pioneer, the Verbatim 43887 or 43890 as these should contain a Pioneer BDR-UD03 inside that may be able to be cross-flashed to BDR-UD04 firmware for UHD compatibility.
nicholfd
Post by nicholfd »
Thank you,
LGSONE
A compatible drive that is available (all models are becoming more & more scarce).
See the "For Sale" threads in this forum:
Drives for sale, Flashing Services, where to buy...
My drives available for sale are linked in my signature. My e-mail address is also listed there if you are interested in contacting me for one of the drives I have for sale (all are pre-flashed for DVD/Blu-Ray/4K/UHD use with MakeMKV).
Thanks,
Frank
For sale:
trolnator
Post by trolnator »
Hi All,
Kind regards,
the info is the following:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: DIDL121264WL
Firmware date: 2020-07-21
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: E116/ID71
Thanks for the help, I am really new to all this :)
cpatullo
Post by cpatullo »
New to the forum.
I have been ripping my Bluray and DVD collection for about a year now and am getting close to done. Running into some discs/series that aren't working.
So, figured it was time to flash the drive and see how it all does after that.
I have the following:
Current profile: DVD-ROM
Product: BD-RE BH16NS40
Revision: 1.05
Firmware date: 2120-05-06 13:31
Highest AACS version: 72
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Which firmware should I flash to this drive, and after the initial flash due to encryption, should I flash to a newer firmware?
Thanks in advance!
trolnator wrote:
Mon Dec 22, 2025 8:48 am
Hi All,
Kind regards,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
PM sent.
cpatullo wrote:
Mon Dec 22, 2025 3:35 pm
New to the forum.
Revision: 1.05
Thanks in advance!
The recommended firmware for your drive is WH16NS60 1.02-MK. Just the flash it and you are all good.
cpatullo
Post by cpatullo »
Thank you! All worked well!
