Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Hi. I just received a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ************
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Re: Asus BW-16D1X-U
Pm senrKDick wrote: Sat Dec 20, 2025 5:33 pm Hi. I just received a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Re: Asus BW-16D1X-U
I tried, but it doesn't work. I get this error message. "Drive and Firmware hardware types don't match." Thank you for your help.Coopervid wrote: Sat Dec 20, 2025 10:46 pmPm senrKDick wrote: Sat Dec 20, 2025 5:33 pm Hi. I just received a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Re: Asus BW-16D1X-U
You must check the force flash box.KDick wrote: Sun Dec 21, 2025 5:07 pmI tried, but it doesn't work. I get this error message. "Drive and Firmware hardware types don't match." Thank you for your help.Coopervid wrote: Sat Dec 20, 2025 10:46 pmPm senrKDick wrote: Sat Dec 20, 2025 5:33 pm Hi. I just received a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Re: Asus BW-16D1X-U
This happens when people don't READ and FOLLOW INSTRUCTIONs.
Re: Asus BW-16D1X-U
Thanks, The serial number sticker on the enclosure has a build date of Sept 2025, and its an LG drive inside. I flashed the 16NS60 1.02MK firmware and all is good.Coopervid wrote: Fri Dec 19, 2025 3:33 pmCorrect. But if it's a Pioneer drive inside the firmware must be older than Dec. 2022 to enable UHD capability. Buy it and if the firmware is younger return it. If a LG is inside you can flash it with the tools available in the forum.KidJoe wrote: Fri Dec 19, 2025 3:27 pm My LG WH16NS40 just died, so I'm going to have to purchase something. Pricing and availability varies, but the local Microcenter has Asus BW-16D1X-U in stock for the same price I'm seeing online. So I was thinking of picking one up after reading this thread.
It looks like the most recent posters are getting a Pioneer drive in the enclosure when purchasing an Asus BW-16D1X-U. And while the firmware and process isn't posted, it is flashable (and usable with MakeMKV) with PM being sent. Is that correct?
Re: Asus BW-16D1X-U
Okay, it's done. Everything is working perfectly. Thank you.
Re: Asus BW-16D1X-U
That's true! Next time I'll be more careful.Coopervid wrote: Sun Dec 21, 2025 8:46 pm This happens when people don't READ and FOLLOW INSTRUCTIONs.
BleckToMare
Re: Asus BW-16D1X-U
Hi everyone, I just got a new Asus drive and I'd like to rip 4K disks. Can someone help? Here's the informations:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 20
Thanks in advance.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Thanks in advance.
Re: Asus BW-16D1X-U
Sure just email me that drive info section see below for emailBleckToMare wrote: Mon Dec 22, 2025 7:14 pm Hi everyone, I just got a new Asus drive and I'd like to rip 4K disks. Can someone help? Here's the informations:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Thanks in advance.
Re: Asus BW-16D1X-U
I just bought an Asus BW-16D1X-U and would like to use it to rip 4K videos. I have tested it with regular BluRay and it works fine but it will not recognize any 4K UHD movies.
Can anyone help me?
Drive info below:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 14
Can anyone help me?
Drive info below:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Re: Asus BW-16D1X-U
See guide below or email me or Marty for a auto flasherhenrydc wrote: Wed Jan 07, 2026 4:22 am I just bought an Asus BW-16D1X-U and would like to use it to rip 4K videos. I have tested it with regular BluRay and it works fine but it will not recognize any 4K UHD movies.
Can anyone help me?
Drive info below:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Re: Asus BW-16D1X-U
I just got a BW-16D1X-U today.
I think my drive/firmware indicates it should be supported. Could someone confirm? (Attaching drive sticker)
When I plug it in and view in Make MKV, it says to email the firmware to support@makemkv.com. is this a generic message or is this a new firmware that should be sent?
Here is the drive info from MKV
Interestingly the software shows the revision as A105, but the sticker on the drive says A205. That seems strange.
Drive Information OS
device name: E:
Manufacturer: ASUS
Product: BW-160 1X-U
Revision: A105
Highest AACS version: 60
Drive platform: MT1959Interestingly the software shows the revision as A105, but the sticker on the drive says A205. That seems strange.
Re: Asus BW-16D1X-U
If MakeMKV is asking for it, send the dump in to support@makemkv.com.aitee wrote: Thu Jan 08, 2026 1:27 am I just got a BW-16D1X-U today.
Here is the drive info from MKVCode: Select all
Drive Information OS device name: E: Current profile: BD-ROM Manufacturer: ASUS Product: BW-160 1X-U Revision: A105 Firmware date: 2120-12-02 11:14 Bus encryption flags: 1F Highest AACS version: 60 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
You can flash this drive. WH16NS60 1.02-MK is the recommended firmware.
Re: Asus BW-16D1X-U
Somehow my image did not attach.
Not sure how to get it properly in an image tag or attachment. So I uploaded it here:
https://imgur.com/a/IplDcrm
