Backup Failed - AACS Dump attached
neurocrash
Post by neurocrash »
Here is the log:
Backing up disc into folder "Z:/Music/Incoming/Bluray Audio to Extract/backup/INXS"
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?Zve8Cy8aw+vie/...
Saved AACS dump file as D:/Ripping Temp/MKB_v82_INXS_D842.tgz
Backup failed
Re: Backup Failed - AACS Dump attached
Regular blu-rays that use the latest version of encryption, AACS v82, have to handled slightly differently than regular blu-rays with older versions of encryption.
MakeMKV supports two different disc decryption mechanisms. The built-in mechanism is called hashed keys and it works with all dumps from MakeMKV regardless of the brand of drive. When there is not a key for you disc and MakeMKV produces a dump, email that dump to svq@makemkv.com. Eventually a hashed key will be produced and MakeMKV will automatically download it as needed.
The other source for decryption keys is the public keyDB. The first post in the Public KeyDB Disc Submissions thread includes a template and instructions on how to submit dumps for inclusion in the keyDB. It also has links to where the keyDB can be downloaded, utilities to help keep it updated, and where to put the file so MakeMKV can use it. Dumps from Pioneer drives can't generally be used for keyDB submissions. However, MakeMKV can use the keys provided by the public keyDB with any brand of optical drive.
These two ways to decrypt discs can be used together. If you can submit a dump to the keyDB you can also email it to svq@makemkv.com. Accidental duplicates emailed to MakeMKV aren't a big deal but duplicates submitted to the keyDB should be avoided if possible.
