Pioneer RS8F00
cowgoo
Re: Pioneer RS8F00
Hi I just got a Pioneer RS8F00 and am looking to get uhd from it
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Pioneer RS8F00
sure just email me that makemkv drive infoetcetera wrote: Sun Dec 21, 2025 8:02 pm Can anybody help where I should post the inquiry? Been a few days and no reply in this forum so maybe there's a more suitable one. Thanks.
etcetera wrote: Tue Dec 16, 2025 8:39 am Wonder if I can make this drive read UHD. Thanks.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: **********
Highest AACS version: 68
darch
Re: Pioneer RS8F00
Thanks. Worked perfectly.Coopervid wrote: Sat Dec 20, 2025 10:44 pmPM sent.darch wrote: Sat Dec 20, 2025 7:00 pm I have one of these that I'd like to get UHD-capable. I've got Linux and Mac, if that matters.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
TimeSpace
Re: Pioneer RS8F00
Coopervid, Sorry for the late reply, thank you so much for reaching out via PM. I truly appreciate your help. The information you provided worked seamlessly.Coopervid wrote: Mon Dec 01, 2025 10:00 amPM sent.TimeSpace wrote: Sun Nov 30, 2025 10:54 pm I also have an ASUS BW-16D1X-U, but the Drive platform is listed as a: Pioneer RS8F00. I am new to the forum, but I figured posting in an existing one that best matched my situation might make more sense.
This is my drive information with the Serial number omitted :I tried to review the main thread "Ultimate UHD Drives Flashing Guide Updated 2025", but this drive is not listed, but one like it is listed, but it sort of indicated it would be an LG, but based on the info it is a Pioneer RS8F00. Anyhow I got a little confused and figured I might ask some question before proceeding in an effort to avoiding any chance at bricking it.Code: Select all
Drive Information OS device name: G: Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76 No disc inserted
Any help would be much appreciated,
Thanks.
beust
Re: Pioneer RS8F00
Hi !
I also have an ASUS BW-16D1H-U PRO, but the Drive platform is listed as a: Pioneer RS8F00. Here are the specs
I take any help to read UHD on it
thanks a lot in advance !
Informations lecteur
Nom du lecteur SE : F:
Profil actuel : BD-R SRM
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : ************
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 75
Firmware version: E116/ID71
egreen
Re: Pioneer RS8F00
Hey Cooper, In the same boat with an ASUS BW-16D1X-U on the Pioneer RS8F00 drive platform. Tried to PM you, but I just registered and can't send the message yet. Drive details from MakeMKV below, any help is appreciated!Coopervid wrote: Thu Oct 30, 2025 9:01 pmPM sent.Rabiddog wrote: Thu Oct 30, 2025 10:40 am Just purchased this drive asus BW-16D1X-U makemkv shows this info
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Highest AACS version: 82
Looking for the correct firmware to flash
Any help will be gladly appreciated thanks
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Highest AACS version: 76
Re: Pioneer RS8F00
PM sent.egreen wrote: Sat Dec 27, 2025 5:37 pmHey Cooper, In the same boat with an ASUS BW-16D1X-U on the Pioneer RS8F00 drive platform. Tried to PM you, but I just registered and can't send the message yet. Drive details from MakeMKV below, any help is appreciated!Coopervid wrote: Thu Oct 30, 2025 9:01 pmPM sent.Rabiddog wrote: Thu Oct 30, 2025 10:40 am Just purchased this drive asus BW-16D1X-U makemkv shows this info
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
egreen
Re: Pioneer RS8F00
Thanks Cooper, it works perfectly and you could not have made it any easier.
For anyone considering this drive, the build quality is pretty suspect with lightweight plastics everywhere, but it operates beautifully. I am not sure why/how Asus got their hands on a bunch of Pioneer drives but they are super smooth and unbelievably quiet. Like you have to put your ear next to the drive to hear it. Hopefully it holds up over time; I will be getting a second one as an insurance policy before this manufacturing run ends.
elflash444
Re: Pioneer RS8F00
OS device name: E:
Current profile: BD-R SRM
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Disc Information
Data capacity: 0.0 Gb
Disc type: BD-R
Number of layers: 2
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Disc Information
Disc type: BD-R
Number of layers: 2
elflash444
Re: Pioneer RS8F00
hello cooper can you send me it too please
Re: Pioneer RS8F00
PM sent.elflash444 wrote: Sun Dec 28, 2025 8:53 am OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Disc Information
Disc type: BD-R
Number of layers: 2
Zayll13
Re: Pioneer RS8F00
OS device name: E:
Current profile: CD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: XXXXXXXXXX
I seem to have gotten one of these for Christmas. I see this drive is flash-able, could I have help with the firmware please. Playing regular Blue-rays on this is pretty nice so far. Thank you for any help if possible. Hope everyone is having a great day. If you need anything from me just let me know. Thank you.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Pioneer RS8F00
PM sent.Zayll13 wrote: Wed Dec 31, 2025 10:01 am Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Zayll13
Re: Pioneer RS8F00
Worked like a charm, easy instructions to follow and UHD playback is smooth and fast. I appreciate the help! Hope you have a wonderful new year!Coopervid wrote: Thu Jan 01, 2026 1:00 pmPM sent.Zayll13 wrote: Wed Dec 31, 2025 10:01 am Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
speerk30
Re: Pioneer RS8F00
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
A friend of mine picked me up this over the holidays, because I built a NAS, and he mentioned running Jellyfin off it. That I could use this to rip my Blu-ray TV/Movie collection for streaming if I flashed it, and used MakeMKV. I'm new to this, and wasn't sure what to flash? All my 4k & regular blu-ray discs are bought in the US, so not sure if region matters.
My friend said he tried to get the Asus BW-16D1HT, but was out of stock so he got this. I waasn't sure looking at the all you need firmware pack if that Asus BW-16D1HT firmware works for this model too? Apologies if silly questions.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
