MakeMKV won't even open DVD on Buffalo BRXL-PUS6U3B
Woody
Post by Woody » Sun Dec 21, 2025 8:16 pm
Had a deal on a BRXL-PUS6U3B, so I thought I'd grab one to try and rip some Blu-rays while I searched for a better UHD-capable drive.
I thought LibreDrive was just for UHD's so if I'm wrong I'll apologize and spend the holidays reading the guide.
To clarify, I have the BRXL-PUS6U3B attached to my Ubuntu laptop with two cables attached to the Sabrent USB 3.0 10 port hub.
The USB hub is obviously plugged in. The BRXL-PUS6U3B is attached to the hub via a) the included USB cable and b) the USB to barrel jack connector. The LED on top of the BRXL-PUS6U3B is flashing red, but the manual states that the LED may blink red even if it is getting enough power. EDIT: powered everything down and back up again. LED is now a solid green but still no go on opening DVD or Blu-ray.
If I insert a Blu-ray, MakeMKV will have the drive seeking but will not open it. Again, to clarify does LibreDrive need to be enabled for Blu-rays or is that just for UHD?
Thinking that it may need to be enabled for Blu-rays as well, I decided to toss a DVD in the drive. The DVD would not open in MakeMKV - just seeking noise - but it did mount as a DVD in the file manager and it was playable via SMPlayer.
Running under Ubuntu and just upgraded to MakeMKV 1.18.2.
Thanks for any advice on why MakeMKV isn't even opening a DVD and whether I need LibreDrive enabled for even Blu-rays.
MakeMKV Drive info:
Device: /dev/sr1
Manufacturer: Buffalo
Revision: BN14
Firmware date: 2121-06-21 13:33
Bus Encryption flags: 1F
Re: MakeMKV won't even open DVD on Buffalo BRXL-PUS6U3B
Post by Coopervid » Sun Dec 21, 2025 8:59 pm
Woody wrote: Sun Dec 21, 2025 8:16 pm Had a deal on a BRXL-PUS6U3B, so I thought I'd grab one to try and rip some Blu-rays while I searched for a better UHD-capable drive.
MakeMKV Drive info:
Device: /dev/sr1
Revision: BN14
Downgrade to 1.17.7 and flash BU40N 1.00.
Woody
Post by Woody » Sun Dec 21, 2025 9:07 pm
Thanks. I'll hit the guide. Are there tools to do this in Ubuntu or do I need to dig up a Windows machine?
