https://makemkv.com/download/old/fedeb wrote: Fri Dec 19, 2025 1:04 pm can someone update the post for Linux instructions?
The MKV for linux points to 1.18.2 version viewtopic.php?f=3&t=224
But this guide viewtopic.php?f=16&t=19634 tells that we must use 1.17.7 version
How we can install 1.17.7 if the only working version is 1.18.2 ?
Hi All,
I recently purchased an ASUS_BW-16D1H-U_E116_DIDL121264WL but when I try to flash it it just says it does not have the correct drive platform.
Did I purchase the wrong device or can someone help me with this please?
Any info or help is much appreciated, thanks a lot in advance!
Kind regards,
Kind regards,
It's a Pioneer drive. Post the MakeMKV drive info and libredrive info sections.trolnator wrote: Sun Dec 21, 2025 8:41 pm Hi All,
Kind regards,
Can these things be shucked and installed directly into a PC?MartyMcNuts wrote: Mon Dec 22, 2025 12:42 amIt's a Pioneer drive. Post the MakeMKV drive info and libredrive info sections.trolnator wrote: Sun Dec 21, 2025 8:41 pm Hi All,
Kind regards,
Pretty sure they can. It should be a standard SATA drive inside.Mr_Orange wrote: Mon Dec 22, 2025 12:45 amCan these things be shucked and installed directly into a PC?MartyMcNuts wrote: Mon Dec 22, 2025 12:42 amIt's a Pioneer drive. Post the MakeMKV drive info and libredrive info sections.trolnator wrote: Sun Dec 21, 2025 8:41 pm Hi All,
Kind regards,
Thanks Marty. Are they:MartyMcNuts wrote: Mon Dec 22, 2025 12:48 amPretty sure they can. It should be a standard SATA drive inside.Mr_Orange wrote: Mon Dec 22, 2025 12:45 amCan these things be shucked and installed directly into a PC?MartyMcNuts wrote: Mon Dec 22, 2025 12:42 am
- UHD ready;
- need flashing; or
- enabled by the SDF.bin update
Most likely will need to be flashed with software/firmware available on these forums.Mr_Orange wrote: Mon Dec 22, 2025 12:51 amThanks Marty. Are they:MartyMcNuts wrote: Mon Dec 22, 2025 12:48 amPretty sure they can. It should be a standard SATA drive inside.Mr_Orange wrote: Mon Dec 22, 2025 12:45 am
- UHD ready;
- need flashing; or
No way to tell for sure until the owner posts their drive MAkeMKV info (Mfg's will change/vary the internal drive mechanism even in the same model USB chassis).
All of this model chassis I've seen have drives that can be flashed for MakeMKV/4K/UHD.
Just checked, and I have the more common US model #/version (may be exact same, if his model came from package tag/barcode) of that drive for sale, pre-flashed. Link to the "For sale" thread in my signature, along with my e-mail address.
EDIT - And yes, they can be removed from the USB chassis & installed in a desktop PC. Remove the back 2 rubber feet, and remove 2 screws. Two shells of the chassis snap apart. Verified on the drives I have for sale.
Thanks,
Frank
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
G: HL-DT-ST_BD-RE__WH14NS40_1.01_211304042325_K92DAVC0827
Stumbled upon this as I just fired up this machine to back up some BR's. I purchased makeMKV in 2021; it worked well, but I'm now experiencing issues. Looks like the drive in use cannot be flashed. Is this correct? I have been reviewing this, and before I go to eBay, I wanted to check.
If it is unable and you were buying a drive today, what would be the "best"/one to get?
Thank you,
LGSONE
Thank you,
LGSONE
Nope, too old. Manufactured in 2013 and would have the old MT1939 drive platform.LGSONE wrote: Mon Dec 22, 2025 4:21 am G: HL-DT-ST_BD-RE__WH14NS40_1.01_211304042325_K92DAVC0827
Thank you,
LGSONE
Best one to get is any Pioneer but the world's supply is dwindling fast! If you can't get a Pioneer, the Verbatim 43887 or 43890 as these should contain a Pioneer BDR-UD03 inside that may be able to be cross-flashed to BDR-UD04 firmware for UHD compatibility.
A compatible drive that is available (all models are becoming more & more scarce).
See the "For Sale" threads in this forum:
Drives for sale, Flashing Services, where to buy...
My drives available for sale are linked in my signature. My e-mail address is also listed there if you are interested in contacting me for one of the drives I have for sale (all are pre-flashed for DVD/Blu-Ray/4K/UHD use with MakeMKV).
Thanks,
Frank
the info is the following:MartyMcNuts wrote: Mon Dec 22, 2025 12:42 amIt's a Pioneer drive. Post the MakeMKV drive info and libredrive info sections.trolnator wrote: Sun Dec 21, 2025 8:41 pm Hi All,
Kind regards,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: DIDL121264WL
Firmware date: 2020-07-21
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: E116/ID71
Thanks for the help, I am really new to all this
New to the forum.
I have been ripping my Bluray and DVD collection for about a year now and am getting close to done. Running into some discs/series that aren't working.
So, figured it was time to flash the drive and see how it all does after that.
I have the following:
Current profile: DVD-ROM
Product: BD-RE BH16NS40
Revision: 1.05
Firmware date: 2120-05-06 13:31
Highest AACS version: 72
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Which firmware should I flash to this drive, and after the initial flash due to encryption, should I flash to a newer firmware?
Thanks in advance!
Revision: 1.05
Thanks in advance!
PM sent.trolnator wrote: Mon Dec 22, 2025 8:48 amthe info is the following:MartyMcNuts wrote: Mon Dec 22, 2025 12:42 amIt's a Pioneer drive. Post the MakeMKV drive info and libredrive info sections.trolnator wrote: Sun Dec 21, 2025 8:41 pm Hi All,
Kind regards,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Thanks for the help, I am really new to all this![]()
The recommended firmware for your drive is WH16NS60 1.02-MK. Just the flash it and you are all good.cpatullo wrote: Mon Dec 22, 2025 3:35 pm New to the forum.
Revision: 1.05
Thanks in advance!
Thank you! All worked well!
