New to drive flashing WH16NS60
retromaniacjames
Post by retromaniacjames » Sun Dec 21, 2025 4:15 am
I am interested in upgrading my drive to LibreDrive but I am not exactly sure how to do it, Looks like my current firmware is too high being 1.03 that I need to downgrade to 1.02 and then flash the patch to it. I want to get the drive flashed but I also do not want to attempt it and mess it up resulting in a doorstop.
Can someone more familiar with this please explain it to me in baby steps.
This is what MakeMKV reports for my drive, and I have used the SDF tool to backup my current firmware, the drive works for reading and writing discs currently.
BD-RE HL-DT-ST BD-RE WH16NS60 1.03 KLVK59E4513
Current profile: DVD-ROM
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLVK59E4513
Firmware date: 2120-05-08 10:10
Highest AACS version: 70
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Re: New to drive flashing WH16NS60
Post by MartyMcNuts » Sun Dec 21, 2025 4:33 am
retromaniacjames wrote: Sun Dec 21, 2025 4:15 am I am interested in upgrading my drive to LibreDrive but I am not exactly sure how to do it, Looks like my current firmware is too high being 1.03 that I need to downgrade to 1.02 and then flash the patch to it. I want to get the drive flashed but I also do not want to attempt it and mess it up resulting in a doorstop.
Revision: 1.03
Flash directly to WH16NS60 1.02-MK and you are good to go.
retromaniacjames
Post by retromaniacjames » Sun Dec 21, 2025 5:02 am
okay because I downloaded the mk-firmware-pack-20200720.zip and inside I see a single firmware file that has the filename
HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.BIN
is the the correct patched file to flash onto the drive, or is that an old original firmware?
the folder structure inside the archive is MK / HL-DT-ST/WH16NS60/
Post by MartyMcNuts » Sun Dec 21, 2025 5:28 am
retromaniacjames wrote: Sun Dec 21, 2025 5:02 am okay because I downloaded the mk-firmware-pack-20200720.zip and inside I see a single firmware file that has the filename
In that firmware pack, inside the "MK/old" folder is the WH16NS60 1.02 firmware.
retromaniacjames
Post by retromaniacjames » Sun Dec 21, 2025 9:06 pm
okay thank you :D
and just to make sure I fully understand, all i need to do is in the mk/old folder find that firmware file and flash that to the drive and it is a already patched libredrive firmware for the drive.
Because I read before I had to downgrade and then flash the patched firmware. That was the main part I was confused about before but if I don't need to worry about that then awesome
Post by MartyMcNuts » Mon Dec 22, 2025 12:41 am
retromaniacjames wrote: Sun Dec 21, 2025 9:06 pm okay thank you :D
Yep, just flash the WH16NS60 1.02 from the MK/old folder and it's done!
retromaniacjames
Post by retromaniacjames » Mon Dec 22, 2025 6:58 am
Thank you MartyMcNuts! Just finished flashing the drive (after I took 2 regular firmware dumps, and 2 firmware dumps with bootloader enabled), figured that would be the best option is it failed flashing but worked first attempt!
OS device name: E:
Revision: 1.02
Serial number:
Firmware version: 1.02
