Dexter - Original Sin (Blu-Ray) Fails To Rip (Decrypt)
patrick
#1 Post by patrick » Mon Dec 08, 2025 4:00 am
The TV Series "Dexter - Original Sin (Season1)" (Blu-Ray) fails to Decrypt succesfully as it uses a newer version of AACS protection (AACS v82) even using my Asus Libredrive (BW-16D1HT Disk drive) (Un-patched firmware - v3.01)
I let you guys know also by visting your attached link on the Make MKV program.
Make MKV program stated : that the volume key is unknown for this disk - video cant be decrypted. I look foward to the issue to be fully resolved, Thx Guys
Re: Dexter - Original Sin (Blu-Ray) Fails To Rip (Decrypt)
#2 Post by dcoke22 » Mon Dec 08, 2025 4:08 am
At the moment, MakeMKV does not natively support AACS v82 blu-rays. You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread.
patrick
#3 Post by patrick » Mon Dec 08, 2025 11:49 pm
OK, Will do, Thankyou for the quick reply.
patrick
Re: Dexter - Original Sin (Blu-Ray) is now Decypted & ripping 🙏
#4 Post by patrick » Sun Dec 21, 2025 4:05 am
Quick update: Dexter - Original Sin appears to be ripping now, 1st disk is ripping as i write this. So thankyou guys
