Asus BW-16D1X-U
KDick
Re: Asus BW-16D1X-U
Post by KDick » Sat Dec 20, 2025 5:33 pm
Hi. I just received a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ************
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
Re: Asus BW-16D1X-U
Post by Coopervid » Sat Dec 20, 2025 10:46 pm
KDick wrote: Sat Dec 20, 2025 5:33 pm Hi. I just received a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Pm senr
KDick
Re: Asus BW-16D1X-U
Post by KDick » Sun Dec 21, 2025 5:07 pm
Coopervid wrote: Sat Dec 20, 2025 10:46 pm
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Pm senr
I tried, but it doesn't work. I get this error message. "Drive and Firmware hardware types don't match." Thank you for your help.
Re: Asus BW-16D1X-U
Post by MartyMcNuts » Sun Dec 21, 2025 8:40 pm
KDick wrote: Sun Dec 21, 2025 5:07 pm
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Pm senr
You must check the force flash box.
Re: Asus BW-16D1X-U
Post by Coopervid » Sun Dec 21, 2025 8:46 pm
This happens when people don't READ and FOLLOW INSTRUCTIONs.
KidJoe
Re: Asus BW-16D1X-U
Post by KidJoe » Mon Dec 22, 2025 1:32 am
Coopervid wrote: Fri Dec 19, 2025 3:33 pm
KidJoe wrote: Fri Dec 19, 2025 3:27 pm My LG WH16NS40 just died, so I'm going to have to purchase something. Pricing and availability varies, but the local Microcenter has Asus BW-16D1X-U in stock for the same price I'm seeing online. So I was thinking of picking one up after reading this thread.
It looks like the most recent posters are getting a Pioneer drive in the enclosure when purchasing an Asus BW-16D1X-U. And while the firmware and process isn't posted, it is flashable (and usable with MakeMKV) with PM being sent. Is that correct?
Correct. But if it's a Pioneer drive inside the firmware must be older than Dec. 2022 to enable UHD capability. Buy it and if the firmware is younger return it. If a LG is inside you can flash it with the tools available in the forum.
Thanks, The serial number sticker on the enclosure has a build date of Sept 2025, and its an LG drive inside. I flashed the 16NS60 1.02MK firmware and all is good.
KDick
Re: Asus BW-16D1X-U
Post by KDick » Mon Dec 22, 2025 2:58 pm
MartyMcNuts wrote: Sun Dec 21, 2025 8:40 pm
Pm senr
Okay, it's done. Everything is working perfectly. Thank you.
KDick
Re: Asus BW-16D1X-U
Post by KDick » Mon Dec 22, 2025 3:03 pm
Coopervid wrote: Sun Dec 21, 2025 8:46 pm This happens when people don't READ and FOLLOW INSTRUCTIONs.
That's true! Next time I'll be more careful. :D
BleckToMare
Re: Asus BW-16D1X-U
Post by BleckToMare » Mon Dec 22, 2025 7:14 pm
Hi everyone, I just got a new Asus drive and I'd like to rip 4K disks. Can someone help? Here's the informations:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 20
Thanks in advance.
Re: Asus BW-16D1X-U
Post by Billycar11 » Mon Dec 22, 2025 9:20 pm
BleckToMare wrote: Mon Dec 22, 2025 7:14 pm Hi everyone, I just got a new Asus drive and I'd like to rip 4K disks. Can someone help? Here's the informations:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Thanks in advance.
Sure just email me that drive info section see below for email
henrydc
Re: Asus BW-16D1X-U
Post by henrydc » Wed Jan 07, 2026 4:22 am
I just bought an Asus BW-16D1X-U and would like to use it to rip 4K videos. I have tested it with regular BluRay and it works fine but it will not recognize any 4K UHD movies.
Can anyone help me?
Drive info below:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 14
Re: Asus BW-16D1X-U
Post by Billycar11 » Wed Jan 07, 2026 4:25 am
henrydc wrote: Wed Jan 07, 2026 4:22 am I just bought an Asus BW-16D1X-U and would like to use it to rip 4K videos. I have tested it with regular BluRay and it works fine but it will not recognize any 4K UHD movies.
Can anyone help me?
Drive info below:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
See guide below or email me or Marty for a auto flasher
aitee
Re: Asus BW-16D1X-U
Post by aitee » Thu Jan 08, 2026 1:27 am
I just got a BW-16D1X-U today.
I think my drive/firmware indicates it should be supported. Could someone confirm? (Attaching drive sticker)
When I plug it in and view in Make MKV, it says to email the firmware to support@makemkv.com. is this a generic message or is this a new firmware that should be sent?
Here is the drive info from MKV
Drive Information OS
device name: E:
Manufacturer: ASUS
Product: BW-160 1X-U
Revision: A105
Highest AACS version: 60
Interestingly the software shows the revision as A105, but the sticker on the drive says A205. That seems strange.
Re: Asus BW-16D1X-U
Post by MartyMcNuts » Thu Jan 08, 2026 2:08 am
aitee wrote: Thu Jan 08, 2026 1:27 am I just got a BW-16D1X-U today.
device name: E:
Manufacturer: ASUS
Revision: A105
If MakeMKV is asking for it, send the dump in to support@makemkv.com.
You can flash this drive. WH16NS60 1.02-MK is the recommended firmware.
aitee
Re: Asus BW-16D1X-U
Post by aitee » Thu Jan 08, 2026 4:32 am
Somehow my image did not attach.
Not sure how to get it properly in an image tag or attachment. So I uploaded it here:
https://imgur.com/a/IplDcrm
