AACS Dump (New, can't be ripped)
Squirrel
Attached the zip file, I have no idea how this works ngl but I figured someone would be able to add the decryption to MakeMKV using the attachment.
Re: AACS Dump (New, can't be ripped)
No attachment seen, which likely means the file was bigger than allowed (4.0mb). You should email the file to svq@makemkv.com anyway, if you want it added to MakeMKV.
Additionally, if you want it added to the keydb, you would need to upload it to a public site (such as Google or ???) and post the link here, so that the powers-that-keydb can fetch it, then add it to the public database.
Squirrel
Thank You!! Sorry for the late reply, I just typically don't use these forums. Will email them the file if I still can't rip the bluray.
