MKVChaps - does anyone have a copy?
oscillator
#1 Post by oscillator » Wed Feb 29, 2012 12:31 am
I lost my copy of MKVChaps from this post:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=690
Anyways, I can't download it again since it was hosted on megaupload. I tried using the code listed in the post but that is, as they say, outside my wheelhouse.
If anyone can upload a copy of it that would be great.
Thanks.
setarip_old
Re: MKVChaps - does anyone have a copy?
#2 Post by setarip_old » Wed Feb 29, 2012 2:26 am
Have you tried to PM or email "Wasabi"?
Smithcraft
#3 Post by Smithcraft » Wed Feb 29, 2012 9:07 am
I might still have it on my peecee but I only use it on the weekends.
I never got it to work, so I don't know if there is something wrong with it(corrupted download) or something else is wrong with it(pebkac most likely).
SC
robpdotcom
#4 Post by robpdotcom » Wed Feb 29, 2012 2:57 pm
oscillator
#5 Post by oscillator » Wed Feb 29, 2012 10:43 pm
robpdotcom wrote:Here you go:
http://www.mediafire.com/?7l85net8dddle84
Thank you!
piccirilli
#6 Post by piccirilli » Mon Mar 05, 2012 7:58 pm
I got MKVChaps to work for one file. Now everytime I try to run it, the program crashes.
Note: I was having similar issue with ImgBurn shutting down on startup. Turns out it has something to do with Sandbox running in the background of some antivirus programs. I inactivated the AutoSandbox feature in my Avast Antivirus and the problem was resolved. Perhaps this will help others with the program crashing.
