Flash Query - ASUS SBW-06D5H-U
MagicianMoth
Post by MagicianMoth »
I have the above drive which has stopped ripping DVD and Bluerays (Woks find with cd's) in the last month or two.
Question; Does the drive need flashing and if required where could I can get this from, and what would be the correct one.
MKV Drive details below;
Current profile: DVD-ROM
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number:
Firmware date: 2023-04-20
Highest AACS version: 70
Drive platform: RS8511
Firmware version: E102/ID26
Thanks in advance for any help
Re: Flash Query - ASUS SBW-06D5H-U
MagicianMoth wrote: Sat Dec 20, 2025 11:55 am I have the above drive which has stopped ripping DVD and Bluerays (Woks find with cd's) in the last month or two.
Manufacturer: ASUS
Revision: E102
Serial number:
Most likely your laser lens is polluted. Clean with alcohol and a cotton swab. Dry with a cotton swab. Your drive's firmware is too new and can't be flashed for UHD.
MagicianMoth
Thanks for the suggestion, I'll give it a try... I'd just be happy to rip DVD's & Bluerays again, I dont go in for UHD at present.
Thanks again
