The Pianist
plexify
The Pianist
Post by plexify » Sat Dec 20, 2025 5:52 am
Not sure if this is just a bad disk (it's fairly old, is double-sided, and has some minor scuffing).
That being said, it plays fine using the AnyDVD software on the same drive.
Edit: That's not actually a true statement - when I press the "play" button from the main menu, I see a trailer for another movie, which then returns to the menu if I hit "next". If I choose the chapter menu and tell it to play chapter 1, then the movie does play.
I tried changing retries and chose each of the 4 modes to no avail.
Here's the details on the drive+disk (it's an old LG Blu-ray rewriter that has not stumbled until this disk):
Current profile: DVD-ROM
Product: BD-RE BH12LS38
Revision: 1.00
Serial number:
Firmware date: 2011-04-27 12:34:56
Bus encryption flags: 1F
Highest AACS version: 81
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.00-D2
Disc Information
Label: THE_PIANIST
Timestamp: 2003-04-15 12:48:18
Protection: CSS/CPPM
Data capacity: 7.93 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
And the log
Debug log started at Sat Dec 20 05:49:37 2025 , written by MakeMKV v1.18.2 win(x64-release)
001005:0000 MakeMKV v1.18.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\me/MakeMKV_log.txt
No  SDF v0a3: HL-DT-ST_BD-RE__BH12LS38_1.00_20110427123456_K99B6G14053
DEBUG: Code 0 at ^\4O;l[]cZAB>C:7o:29396253
DEBUG: Code 0 at lS]g`,`;]*O'8w*t:213136746
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
SDF id v0a3: HL-DT-ST_BD-RE__BH12LS38_1.00_20110427123456_K99B6G14053
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
001003:0020 DEBUG: Code 1 at vBAr0\iw&4N}"od;bo$<kpfi::121262233
001003:0020 DEBUG: Code 2014763 at vBAr0\iw&4N}"od;bo$<kpfi::29394045
001003:0020 DEBUG: Code 0 at (U9Rt(ar=b(tQ:8HE:QqRl':121263406
001003:0020 DEBUG: Code 27498 at OQ5mB%N{eS-nh s5EK$S:213133250
001003:0020 DEBUG: Code 16777216 at OQ5mB%N{eS-nh s5EK$S:121265062
001003:0020 DEBUG: Code 0 at OQ5mB%N{eS-nh s5EK$S:29394689
001003:0020 DEBUG: Code 0 at BOZSFNX;dF]`li:29397104
003038:0000 Cells 20-20 were removed from title end
001003:0020 DEBUG: Code 2014763 at J,>KF1g5~|FZ:':213132721
vobs=ZeNpjYBgFo2AUjIJRMApGwUgDAAgAAAE=
001003:0020 DEBUG: Code 3877646 at J,>KF1g5~|FZ:':29396184
001003:0020 DEBUG: Code 0 at sZX!!/u#\`Sz%uo%;D:121273641
001003:0020 DEBUG: Code 0 at sZX!!/u#\`Sz%uo%;D:121274699
003015:0000 Title #1 (2:29:02) was skipped due to navigation error
Title skip vts=1 pgcn=1
003025:0000 Title #2 has length of 115 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #3 has length of 6 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #4 has length of 25 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #5 has length of 20 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #6 has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Application exited at Sat Dec 20 05:50:21 2025
It isn't going to kill me not to be able to back-up this disk, but I thought it might be useful debugging info
Re: The Pianist
Post by dcoke22 » Mon Dec 22, 2025 4:12 am
plexify
Re: The Pianist
Post by plexify » Wed Dec 24, 2025 9:35 pm
Thanks, yes I did try that and no help.
I think the disk may have some rot, as there is a definite "stain".
This isn't a major issue for me, thanks for your ideas anyway.
