I have managed to successfully build and install makemkv on Fedora 16 x86_64. Unfortunately, running makemkv results in a message "Application failed to initialize". I tried moving the libs it installs to /usr/lib64/, but this did not help. makemkvcon seems to run fine on its own. Cheers.
makemkv does not run on Fedora 16 x86_64
Re: makemkv does not run on Fedora 16 x86_64
Ignore this, it was an old installation lingering in /usr/local interfering with the proper function.
Yeah, once I deleted the stuff from /usr/local.
Well, I just needed it for one blu ray and it worked, so - good I guess
