Dump Submitted - Hellraiser 2022: Turbine (Germany) 4K UHD TGZ File
callumw
Post by callumw »
Steelbook version of Hellraiser 2022 4K UHD from Turbine (release date Dec 11 2025)
src: https://turbine-shop.de/Hellraiser-Das- ... on/6961391
Key file submitted (email): MKB20_v82_HELLRAISER_E90E.tgz
Re: Dump Submitted - Hellraiser 2022: Turbine (Germany) 4K UHD TGZ File
Post by SamuriHL »
Nice. Mine just shipped. Can't wait.
callumw
Post by callumw »
SamuriHL wrote:
Thu Dec 18, 2025 3:57 am
The Bluray ripped fine, it was just the 4K disk that needed submitting.
FYI - I got a mediabook + the steelbook and the dump file/name is the same for both
keydb_helper
Post by keydb_helper »
callumw wrote:
Wed Dec 17, 2025 11:57 pm
Feel free to upload the disc dump file to any file host and post a link here.
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
callumw
Post by callumw »
File was emailed, but here's a direct link:
URL://MKB20_v82_Hellraiser_E90E.tgz
C
keydb_helper
callumw wrote:
Fri Dec 19, 2025 3:17 am
File was emailed, but here's a direct link: ...
Thanks for providing that disc dump file. Your particular disc variant was added to the public keydb on December 14, so grab the very latest keydb and you should be good to go.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
callumw
Post by callumw »
keydb_helper wrote:
Fri Dec 19, 2025 4:58 am
Thanks.
I couldn't get the key file to download automatically, so it's easier for me to just disable internet access and grab it manually from now on. No faffing about with VPNs and waiting for MakeMKV to time out.
Plus I see I can recycle it to use with VLC :)
Out of curiosity, what's the SDF file for?
I'd been getting that manually in the past and see it merge into the _private_data.tar file.
Until you posted the link above, I though those were the key/decryption files, not the keydb file
C
