I just inherited a LG WH16NS40. It had a disk shattered inside of it, I was able to take it apart, remove all the shattered elements clean the laser and generally checked to see if there were any loose elements.
I put the drive back together, got it plugged in and flashed, but it is unable to read even regular DVDs.
Those of you who have repaired drives like this before, what are you typical troubleshooting steps? I am familiar with repairing some computer components, soldering etc.
Make MKV Info Here:
OS device name: I:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:
Highest AACS version: 82
Firmware version: 1.02
WH16NS40 - Optical Drive Repair
Re: WH16NS40 - Optical Drive Repair
check all the ribbon cables for damage and make sure they are all fully in
